Modalità.La modalità di comunicazione senza fili: fino a54Mbps, fino a 217Mbps (impostazione predefinita) e fino a 450Mbps.
Wireless Settings (2.4 GHz and 5 GHz)
The following settings are displayed:
Name (SSID). The wireless network name (SSID) used by the router. The default names for the 5 GHz network ends in -5G to distinguish it from the 2.4 GHz network.
Region. The geographic region where the router is being used. It might be illegal to use the wireless features of the router in some parts of the world.
Channel. The operating channel of the wireless port being used. The default channel is Auto. When Auto is selected, the router selects the best operating channel available. If you notice interference from nearby devices, you can select a different channel. Channels 1, 6, and 11 do not interfere with each other.
Mode. The wireless communication mode: Up to 54 Mbps, Up to 217 Mbps (default), and Up to 450 Mbps.
Wireless AP. Indicates whether the radio feature of the router is enabled. If this feature is not enabled, the Wireless LED on the front panel is off.
Broadcast Name. Indicates whether the router is broadcasting its SSID.
Wireless Isolation. Select this check box in the Basic Home screen only if you want to prevent wireless connections to the router.
Wi-Fi Protected Setup. Indicates whether Wi-Fi Protected Setup is configured for this network.
Scusa ma se volevo trovare queste cose andavo su google
MODE il mio router é impostato a 450 ho provato anche a 217
Quindi presumo che questa chiavetta sul decoder non arriverá mai a 300
Ho cambiato solo la cifratura dal decoder mettendo wpa o wpa2 e magicamente é arrivato a 150
