WOL not working
Tony il Capo
Hi
Wake on Lan on Duo2 seems to be not working. Tried to wake up Duo2 several times, but no luck. I've enabled it in configuration menus.. It worked on original/Black Hole images.
I've last open Black Hole update.
Let me provide You with some details:
1) WakeOnLan enabled in Menu... but it does not work
2) ssh/telnet to box and do "ethtool eth0" shows:
Supports Wake-on: ags
Wake-on: d
Which means that wol is supported but disabled - it should not be when enabled in menu
3) I tried to enable it via: "ethtool -s eth0 wol g" which leads to loosing network -> restart is needed
Could You advice me where to post my issue? I am 100% sure that I am not the only one who has problems with WOL.
If you keep waiting for this to work on openBH, your stb will get old and useless and you were not able to use WOL.:shocked:
Like I said, if you really need this working like I needed, you better flash OpenPLi and you're done! Differences are minimal, performance is greater in OpenPLi and you only miss 'shortcuts', that's what's openBH offers more.
I use WOL a lot on my Duo2, even remotely through SSH tunnel and always works.
