xbmc /kodi
terra
hello all iam new to this getting confused downloaded blackhole image 2.1.4 build 5/12/05/ all working as i want but unable to see anything which looks like xbmx anywhere its vu solo se please advise thanks in advance
I think you have not installed the correct version.
You have to install the BlackHole Xbmc Beta2.
Look on images section for Solo Se, the image is there.
Best regards
Nunigaia
Hi thanks i will have a look can i upgrade without loosing all settings or install as a second image in meoboot .
thanks again....
thanks again....
Blackhole XBMC Beta2 don´t work with MEOBOOT and must be installed in flash memory.
regarding this post from SHIRO, cause Blackhole XMBC BETA1, it´s the same for Blackhole XBMC BETA2 ---> http://www.vuplus-community.net/board/threads/black-hole-xbmc-beta-01.20465/
" Thanks to Shiro for this usefull information "
Hi hello up and running sort of i am unable to to get navi x running script failed i have followed the intructions from bh c
