Xbmc Launcher
stevep
running Black Hole Xbmc beta 02 on vu solo 2.
when i try to start xbmc launcher from plugin menu,it wil not open and box freezes and i have to reboot.
have moved .xbmc folder from /home/root to usb hard drive formatted to media/hdd.
re-flashed box,made no differance.
any advice would be appreciated.
many thanks.
cheers
As Sshiro says regarding Black Hole Xmbc beta 01:
see thread:
http://www.vuplus-community.net/board/threads/black-hole-xbmc-beta-01.20463/
If you have Xbmc on the root directory to not allocate memory rename to /.xbmc
TRICK: To be sure that Xbmc is not filling your flash, after the first Xbmc launch check your filesystem. If you have the folder .Xbmc in the root dir "/.Xbmc" you have to copy it on /media/hdd and then delete from the root.
On beta02 .... you have on /.xmbc root
put the files on the /.xbmc root directory
i think it will fix
Note: You can create on your USB HARD DRIVE a swap space!... instead of what you maded.
thanks,as stated i have deleted .xbmc from home/root and moved to media/hdd/.
plugin will not run,anyone advise where error log is located?
View the files and attributes, maybe is the point.
755 and 644.
If alll has this attributes:
try this:
delete the /.xbmc on your /media/hdd
Install a new fresh image
and
post reply
