XBMC on menu
How do I get XBMC can appear on the menu,,,thanks
AFAIK it´s not possible, instead you can do this:
Set Fast Plugin:
On your RCU, press <GREEN KEY>, and scroll down on plugins until you get XBMC plugin, press <RED KEY>, to assign XBMC as fast plugin ( press <OK> or <GREEN KEY).
Exit Plugins
XBMC is now assigned as fast plugin.
Press <GREEN KEY>, Press <GREEN KEY>
You will execute now XBMC plugin.
