Guys
I have the xbmc beta image installed on my duo2 with two tuners (sat and DT). I had installed the YouTube plugin and was working fine. Lately it has been working very erratically, most of the time hanging the receiver needing a restart.
I have also noticed another fault - my terrestrial tuner might be in conflict with the xbmc
When the xbmc was working I could not set up the tuner ( it hung the receiver)
When I managed to setup the tuner the xbmc stopped working
Anyone with the same problem ?
Thanks for any advice
Hello again guys
With great sadness I had to revert back to the stable blackhole image - I was having more lock-ups than joy
Guys keep up the good work cause it is a beauty when it does work!
Thanks
I have (i thinck) the same probleme. I have a vu+duo2 with xbmc beta 2. Just picture slide shows work fine.
It's impossible for me to exist correctly XBMC. I can't watch anythinck...
If you have a backup with DVB-s / DVB-t ... Thancks...
Bye
Hello,
I want to know how to have French language movies and activate video player on my VU + DUO2.
I also have problems with xbmc lancher, I have filing addons , but not the audio.
I am under blakhole 2.1.6.
Lionel3332,
