XBMC running in small window
sony
The XBMC is shrunk to 1/4 size and a placed in the upper-left corner. How to bring XBMC back to full screen. It was OK at first :( . Image is BH 216.
Ok now all working. Changed skin to old one and in vu settings setup changed resolution to 1080i or 720p
Now all good
What box are you using, as you should be fine with the default skin and full screen xbmc
Am using solo2 but for some reason xbmc and ru%a and a panel addon only display on whole of screen if I use settings I posted above?
