XBMC Wont load on 2.1.4 or 2.1.5
manutd4life
Hi i have currently got BH 2.1.4 beta 2 on my Duo2. I press green and the xbmc loader but it doesn't start. I also tried it on 2.1.5 first and it didn't work hence why i'm currently on 2.1.4 beta 2.
Just put 2.1.5 on, didn't restore my settings. opened xbmc and it opened. Couldn't find Genesis or iFilms. Tried to open up XBMC again, it didnt work so restoring my settings. Anyone got more info on how to get this to work properly? Im using a Duo2
helpppppp,
since a week that i get my solo se and installed 2.1.5, i can't launch xbmc.
when i use the launcher, i get a screen freeze,to return to menu, i hold the power button and then ok.
when i launch xbmc from a telnet session, i get this:
+ CRASHLOG_DIR : /media/hdd
+ HOME : /media/hdd
+ HDD_MOUNT_POINT : /dev/sda1 /media/hdd ext4 rw,relatime,data=ordered 0 0
and then nothing.
any advice on how to debug the problem?
does xbmc use a high resolution that my old old tv can't display?
thanks for any help
i've change a tv and now the vu+ is connected via hdmi, and xbmc work.Seem black scrren is related to the output used on vu+.
