hi xbmc wont load tried reflash and going back to black hole but still wont load can any one help here is the crash log. cheers
############## XBMC CRASH LOG ###############
############### END LOG FILE ################
################ SYSTEM INFO ################
Date: Sat Mar 19 12:54:58 GMT 2016
XBMC Options:
Arch: mips
Kernel: Linux 3.13.5 #1 SMP Thu May 21 02:53:27 CEST 2015
Release: lsb_release not available
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
12:54:54 T:1979265024 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:54:54 T:1979265024 NOTICE: -----------------------------------------------------------------------
12:54:54 T:1979265024 NOTICE: Starting XBMC (13.2 Git:20150206-ed2750e). Platform: MIPS Linux 32-bit
12:54:54 T:1979265024 NOTICE: Using Debug XBMC x32 build, compiled Jun 19 2015 by GCC 4.9.1 for MIPS Linux 32-bit 3.13.0
12:54:55 T:1979265024 WARNING: Unable to determine Linux distribution
12:54:55 T:1979265024 NOTICE: Running on Linux 32-bit (Unknown, 3.13.5 mips)
12:54:55 T:1979265024 NOTICE: Host CPU: BCM7425B2 STB platform, 2 cores available
12:54:55 T:1979265024 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
12:54:55 T:1979265024 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
12:54:55 T:1979265024 NOTICE: special://masterprofile/ is mapped to: /media/hdd/.xbmc/userdata
12:54:55 T:1979265024 NOTICE: special://home/ is mapped to: /media/hdd/.xbmc
12:54:55 T:1979265024 NOTICE: special://temp/ is mapped to: /media/hdd/.xbmc/temp
12:54:55 T:1979265024 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
12:54:55 T:1979265024 NOTICE: Local hostname: vuduo2
12:54:55 T:1979265024 NOTICE: Log File is located: /media/hdd/.xbmc/temp/xbmc.log
12:54:55 T:1979265024 WARNING: Unicode properties are not enabled in PCRE lib, support for national symbols may be limited!
12:54:55 T:1979265024 NOTICE: Consider installing PCRE lib version 8.10 or later with enabled Unicode properties and UTF-8 support. Your PCRE lib version: 8.36 2014-09-26
12:54:55 T:1979265024 NOTICE: -----------------------------------------------------------------------
12:54:55 T:1979265024 DEBUG: ConsoleKit.Manager: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.ConsoleKit was not provided by any .service files
12:54:55 T:1979265024 DEBUG: UPower: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
12:54:55 T:1979265024 DEBUG: DeviceKit.Power: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
12:54:55 T:1979265024 NOTICE: load settings...
12:54:55 T:1979265024 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
12:54:55 T:1979265024 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/linux.xml
12:54:55 T:1979265024 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
12:54:55 T:1979265024 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
12:54:55 T:1979265024 NOTICE: Default DVD Player: dvdplayer
12:54:55 T:1979265024 NOTICE: Default Video Player: dvdplayer
12:54:55 T:1979265024 NOTICE: Default Audio Player: paplayer
12:54:55 T:1979265024 NOTICE: Disabled debug logging due to GUI setting. Level 0.
12:54:55 T:1979265024 NOTICE: Log level changed to 0
12:54:55 T:1979265024 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
12:54:55 T:1979265024 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
12:54:55 T:1979265024 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
12:54:55 T:1979265024 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
12:54:55 T:1979265024 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
12:54:55 T:1979265024 DEBUG: CPlayerCoreConfig::<ctor>: created player E2Player for core 4
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/mms/udp
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
12:54:55 T:1979265024 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dgb
12:54:55 T:1979265024 NOTICE: Loaded playercorefactory configuration
12:54:55 T:1979265024 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
12:54:55 T:1979265024 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
13:54:55 T:1979265024 INFO: creating subdirectories
13:54:55 T:1979265024 INFO: userdata folder: special://masterprofile/
13:54:55 T:1979265024 INFO: recording folder:
13:54:55 T:1979265024 INFO: screenshots folder:
13:54:55 T:1979265024 INFO: load language info file: special://xbmc/language/English/langinfo.xml
13:54:55 T:1979265024 DEBUG: trying to set locale to en_GB.UTF-8
13:54:55 T:1979265024 INFO: global locale set to C
13:54:55 T:1979265024 INFO: load English language file, from path: special://xbmc/language/
13:54:55 T:1979265024 DEBUG: POParser: loaded 3162 strings from file /usr/share/xbmc/language/English/strings.po
13:54:55 T:1979265024 NOTICE: Running database version Addons16
13:54:55 T:1979265024 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-mips.so)
13:54:55 T:1979265024 DEBUG: Loading: /usr/lib/xbmc/system/libcpluff-mips.so
13:54:57 T:1979265024 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/lib/xbmc/addons: No such file or directory'
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository superrepo.kodi.helix.english
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.bstrdsmkr
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.googlecode.anarchintosh-projects
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.xbmc.org
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository superrepo.kodi.jarvis.repositories
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository superrepo.kodi.helix.tv-shows
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.repositories
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.filmkodi.com
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository superrepo.kodi.helix.all
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository superrepo.kodi.helix.external.repositories
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.xbmchub
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository superrepo.kodi.helix.repositories
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.voinage
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.all
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository superrepo.kodi.jarvis.all
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.metalkettle
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.mash2k3
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository superrepo.kodi.helix.sports
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.the-one
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.mikey1234
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository superrepo.kodi.helix.programs
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.superrepo.org.helix.all
13:54:57 T:1979265024 NOTICE: ADDONS: Using repository repository.Jas0npc
13:54:57 T:1979265024 DEBUG: LoadMappings - loaded node "Motorola Nyxboard Hybrid"
13:54:57 T:1979265024 DEBUG: LoadMappings - loaded node "CEC Adapter"
13:54:57 T:1979265024 DEBUG: LoadMappings - loaded node "Pulse-Eight CEC Adapter"
13:54:57 T:1979265024 DEBUG: LoadMappings - loaded node "iMON HID device"
13:54:57 T:1979265024 DEBUG: CPeripheralBusUSB - initialised udev monitor
13:54:57 T:1978786960 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
13:54:57 T:1979265024 DEBUG: UDisks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UDisks was not provided by any .service files
13:54:57 T:1979265024 DEBUG: DeviceKit.Disks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
13:54:57 T:1979265024 DEBUG: Selected UDev as storage provider
13:54:57 T:1979265024 NOTICE: InitWindowSystem: Using EGL Implementation: dvbbox
13:54:57 T:1979265024 DEBUG: EGL initial desktop resolution @ 50.00 - Full Screen
13:54:57 T:1979265024 DEBUG: EGL initial desktop resolution 1280x720 @ 50.00 - Full Screen 3DSBS
13:54:57 T:1979265024 DEBUG: EGL initial desktop resolution 1280x720 @ 50.00 - Full Screen 3DTB
13:54:57 T:1979265024 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
13:54:57 T:1979265024 NOTICE: Previous line repeats 2 times.
13:54:57 T:1979265024 NOTICE: Found (1280x720@50.000000) at 16, setting to RES_DESKTOP at 16
13:54:57 T:1979265024 NOTICE: Checking resolution 16
13:54:57 T:1979265024 DEBUG: CreateWindow: Created surface of size 1280x720
13:54:57 T:1979265024 NOTICE: GL_VENDOR = Broadcom
13:54:57 T:1979265024 NOTICE: GL_RENDERER = VideoCore IV HW (V3D-420)
13:54:57 T:1979265024 NOTICE: GL_VERSION = OpenGL ES 2.0
13:54:57 T:1979265024 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
13:54:57 T:1979265024 DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
13:54:57 T:1979265024 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_APPLE_rgb_422 GL_OES_packed_depth_stencil GL_EXT_debug_marker GL_EXT_multisampled_render_to_texture GL_EXT_texture_format_BGRA8888
13:54:57 T:1979265024 DEBUG: GLES: Extension Support Test - GL_EXT_texture_format_BGRA8888 YES
13:54:57 T:1979265024 DEBUG: GLES: Extension Support Test - GL_IMG_texture_format_BGRA8888 NO
13:54:57 T:1979265024 DEBUG: GLES: Extension Support Test - GL_APPLE_texture_format_BGRA8888 NO
13:54:57 T:1979265024 DEBUG: GL: Vertex Shader compilation log:
13:54:57 T:1979265024 DEBUG: GL: Vertex Shader compiled successfully
13:54:57 T:1979265024 DEBUG: GL: Pixel Shader compilation log:
13:54:57 T:1979265024 DEBUG: GL: Fragment Shader compiled successfully
13:54:57 T:1979265024 DEBUG: GUI Shader [guishader_frag_default.glsl]- Initialise successful : 0x131e528
13:54:57 T:1979265024 DEBUG: GUI Shader [guishader_frag_texture.glsl]- Initialise successful : 0x13221d0
13:54:57 T:1979265024 DEBUG: GUI Shader [guishader_frag_multi.glsl]- Initialise successful : 0x13d2d68
13:54:57 T:1979265024 DEBUG: GUI Shader [guishader_frag_fonts.glsl]- Initialise successful : 0x13d5880
13:54:57 T:1979265024 DEBUG: GUI Shader [guishader_frag_texture_noblend.glsl]- Initialise successful : 0x13ddbf0
13:54:57 T:1979265024 DEBUG: GUI Shader [guishader_frag_multi_blendcolor.glsl]- Initialise successful : 0x13e0600
13:54:57 T:1979265024 DEBUG: GUI Shader [guishader_frag_rgba.glsl]- Initialise successful : 0x13da8c0
13:54:57 T:1979265024 DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external NO
13:54:57 T:1979265024 DEBUG: GUI Shader [guishader_frag_rgba_blendcolor.glsl]- Initialise successful : 0x13dd3d0
13:54:57 T:1979265024 DEBUG: CWinSystemEGL::CreateNewWindow: No need to create a new window
13:54:57 T:1979265024 INFO: GLES: Maximum texture width: 2048
13:54:57 T:1979265024 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
13:54:57 T:1979265024 INFO: load default splash image: /usr/share/xbmc/media/Splash.png
13:54:57 T:1979265024 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-mips.so)
13:54:57 T:1979265024 DEBUG: Loading: /usr/lib/xbmc/system/ImageLib-mips.so
13:54:58 T:1979265024 INFO: load keymapping
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/appcommand.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/gamepad.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.Alienware.Dual.Compatible.Controller.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.AppleRemote.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.Harmony.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.Interact.AxisPad.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.Logitech.RumblePad.2.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.360.Controller.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.Controller.S.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.Nintendo.Wii.U.Pro.Controller.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.PS3.Remote.Keyboard.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.Sony.PLAYSTATION(R)3.Controller.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.WiiRemote.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/joystick.xml
13:54:58 T:1979265024 NOTICE: No Joystick name specified, loading default map
13:54:58 T:1979265024 NOTICE: Previous line repeats 35 times.
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/mouse.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/remote.xml
13:54:58 T:1979265024 INFO: Loading special://xbmc/system/keymaps/touchscreen.xml
13:54:58 T:1979265024 INFO: GUI format 1280x720, Display @ 50.00 - Full Screen
13:54:58 T:1979265024 DEBUG: guilib: Fill viewport on change for solving rendering passes
13:54:58 T:1979265024 DEBUG: SECTION:LoadDLL(libcurl.so.4)
13:54:58 T:1979265024 DEBUG: Loading: libcurl.so.4
13:54:58 T:1979265024 NOTICE: Running database version Addons16
13:54:58 T:1979265024 DEBUG: Initialize, updating databases...
13:54:58 T:1979265024 NOTICE: Running database version ViewModes6
13:54:58 T:1979265024 NOTICE: Running database version Textures13
13:54:58 T:1979265024 NOTICE: Running database version MyMusic46
13:54:58 T:1979265024 NOTICE: Running database version MyVideos78
13:54:58 T:1979265024 NOTICE: Running database version TV22
13:54:58 T:1979265024 NOTICE: Running database version Epg7
13:54:58 T:1979265024 DEBUG: Initialize, updating databases... DONE
13:54:58 T:1979265024 INFO: DPMS: not supported on this platform
13:54:58 T:1979265024 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
13:54:58 T:1979265024 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
13:54:58 T:1979265024 ERROR: Default skin 'skin.confluence' not found! Terminating..
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x13a2800 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x139bc48 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x133ecc8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x133ed88 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x138a510 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x137cb10 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x133ed10 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x133f250 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x133bc50 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x139fb98 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x137cc18 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1358cd8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x136dc18 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x125b1e8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x133e868 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1378e70 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
13:54:58 T:1979265024 DEBUG: PVRManager - destroyed
