Is it possible to stream music amd movies from xbmc running on my PC to my VU+Duo? I can stream TV from the duo to xbmc but not been able to do from xbmc to the duo.
Do I need a plugin for the duo? and is there a guide to streaming from xbmc to duo.
Thanks
If your XBMC box can act as DLNA server you can use DLNA client on your Vu+ box to play DLNA content from XBMC.
Thanks for your reply, I will try to do this. Are there any guides that will help me set this up or can anyone provide help. cheers
