xbox tuner dvb t2
Rendal-Raines
Che ne pensate ?
Qualcuno la ha provata ??
ci sono i drivers ???
$_57.JPG Device IDs
0x045e Vendor ID
0x02d5 Product ID
USB Controller
DiBcom
0700C-XCXXa-G
USB 2.0
D82AC.4
1423-0100-C
Demodulator
Panasonic
MN88472
408P303E
Tuner
NXP
8250B
06 05
ZXD4121
dmesg output
usb 1-3: new high-speed USB device number 4 using ehci-pci
usb 1-3: New USB device found, idVendor=045e, idProduct=02d5
usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-3: Product: Xbox USB Tuner
usb 1-3: Manufacturer: Microsoft Corp.
usb 1-3: SerialNumber: 002493080162
lsusb verbose output
Bus 001 Device 005: ID 045e:02d5 Microsoft Corp.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x045e Microsoft Corp.
idProduct 0x02d5
bcdDevice 1.10
iManufacturer 1 Microsoft Corp.
iProduct 2 Xbox USB Tuner
iSerial 3 002493080162
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
Che ne pensate ?
View attachment 25672 Device IDs
0x045e Vendor ID
0x02d5 Product ID
USB Controller
DiBcom
0700C-XCXXa-G
USB 2.0
D82AC.4
1423-0100-C
Demodulator
Panasonic
MN88472
408P303E
Tuner
NXP
8250B
06 05
ZXD4121
dmesg output
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idProduct 0x02d5
bcdDevice 1.10
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
(Bus Powered)
Non ancora. Manca sostanzialmente un driver per essere potenzialmente compatibile.
ho trovato questa discussione dove sembra sia dib0700
[18.209157] usb 3-3.4.1:new high-speed USB device number 12using xhci_hcd
[18.225327] usb 3-3.4.1:New USB device found, idVendor=045e, idProduct=02d5
[18.225329] usb 3-3.4.1:New USB device strings:Mfr=1,Product=2,SerialNumber=3
[18.225331] usb 3-3.4.1:Product:Xbox USB Tuner
[18.225331] usb 3-3.4.1:Manufacturer:MicrosoftCorp.
[18.225332] usb 3-3.4.1:SerialNumber:002493080162[18.237291] dvb-usb: found a 'Yuan PD378S'in cold state, will try to load a firmware
[18.237639] dvb-usb: downloading firmware from file 'dvb-usb-dib0700-1.20.fw'
[18.304903] dib0700: firmware started successfully.
[18.808356] dvb-usb: found a 'Yuan PD378S'in warm state.
[18.808399] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[18.808418] DVB: registering new adapter (Yuan PD378S)
[18.857884] dib0700: stk7070p_frontend_attach: dib7000p_i2c_enumeration failed.Cannotcontinue
[18.857884]
[18.857888] dvb-usb:no frontend was attached by'Yuan PD378S'
[18.880168]Registered IR keymap rc-dib0700-rc5
[18.880235] input: IR-receiver inside an USB DVB receiver as/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.4/3-3.4.1/rc/rc0/input20
[18.880282] rc0: IR-receiver inside an USB DVB receiver as/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.4/3-3.4.1/rc/rc0
[18.880399] dvb-usb: schedule remote query interval to 50 msecs.
[18.880401] dvb-usb:Yuan PD378S successfully initialized and connected.
[18.880501] usbcore: registered newinterface driver dvb_usb_dib0700
