You Tube TV Audio without Video
Friend aloooooot beter is have last version images becouse is alot fix and last version driver who gived new function
When I used the latest BH some HD channels not work I thought the problem with my ultimo, & then I detect that old BH 1.7.1 or earlier edition this HD channels work with it allredy so I am using old BH, I ask if there is solution ,thanks for all
HD channels work on all images.
We will not and do not support old images.
some HD channels only not work like ( 12284/v/27500/5/6 DVB-s2 on nile sat.) realy not work on ultimo but when i use old BH it is already work.I ask if can merge old BH with new BH or there is somthing to do to make it work with new BH. I think there is sombody has the same problem with his ultimo on this link http://www.vuplus-community.net/board/threads/saudia-tv-hd-nilesat-or-badr.32639/
You can not mix old image with the new one.
There are hundreds of changes.
For the rest we can not help you.
if some channel does not work.You need to know the cause and then you have to ask VU + for help
with an explanation of the problem.
thanks, I only amaze why work with old BH & not work with new BH
Maybe the difference in drivers
or maybe something else works wrong.
Satellite list or satellites.xml is not the same
I do not know .
I can not test Nil sat.
Hello, I have te same problem again with the latest black hole3.0.7,you tub tv plugin play audio only and no video there is a solution , thanks in advance
Hello! This problem has existed for a long time, more than a year.. In my opinion, the problem is the Opera browser that needs to be updated. But, it still no update ((
The plugin works as follows.. When you click on "YouTube TV", a link "http://www.youtube.com/tv" opens in the Opera browser.
Maybe there is some other browser for BH i don't know..
