YouTube
jaroprofe
Hello, I have BlackHole 3.0.9 and I would like to know how to disable, uninstall or protect with password YouYube in this version for my VU + UNO 4k
Enviado desde mi M2002J9G mediante Tapatalk
Matrix10
You would like to delete YouTube TV and not YouTube
plugin.
You can't simply delete YouTubeTV because it's part of the system.
Matrix10
Ok, so Youtube can be disabled or password protected or some way to control its use?
You can remove Chromium folder from
/usr/lib/enigma2/python/Plugins/Extensions/
but then you lose your Chromium browser and YouTubeTV.
You can't just delete YouTubeTV because that module also uses the Chromium browser.
So you have to delete both....Chromium folder.
Backup Chromium folder if you change your mind or have a problem without it
jaroprofe
Thank you so much
