YPrPb colour issue on Vix 2.0
Tony Heaton
I am having a problem with my colour set up on Vix 2.0
My TV does not have HDMI input so I need to use YPrPb with RCA Audio. However, the colour is all weird when I use this A/V output method. I have a kind of megenta haze across the screen.
I can use HDMI-DVI for the picture and there is no issue (Though the RCA input does not work with the DVI channel only the YPrPb) If I connect via scart the collours are all good too. Therefore it is only when using YPrPb output I have the problem.
Anyone know how to fix this issue? I am tearing my hair out at this stage
Have you correctly setup the video output of your box into
Menu -> Setting -> System -> AV Setup ?
Yes I have.
I have tried pretty much every setting from Scart - YPrPb - RGB - HDMI and all with the same result. YPrPb output has a funny colour to it. Could this be an image issue?
Have U Checked the YPrPb color coding, and make sure they are the same connected to TV..?
And make sure the connecting cable is not damaged !
Checked that and even tried changing it around and back again but no joy Im afraid. I think this could be an image bug in Vix 2.0 so I think I will try a different image and see if it is still a problem. Shame because I have all my setting configured for Vix 2.0 now (CAMS, Bouquets, plugins etc). Took me ages to sort the channels into favorites too.
,,,,,,,,Shame because I have all my setting configured for Vix 2.0 now (CAMS, Bouquets, plugins etc). Took me ages to sort the channels into favorites too.
Don't worry,,,,Use software manager @ the image U are using ,,,,to save your enigma2 settlings and more,,,,,!
Then use BH latest image :thumbup:!
Good luck!
