YTTRAILER
i found an ipk package on google for another box, search enigma2-plugin-extensions-yttrailer
you can transfer to temp folder and install manually, but i don't know if it work or not!
When you`re in epg/channel selection, use the tv-button to start the trailer directly or the radio-button to get the trailerlist where you can choose one to start.
