Zapping bouquets using arrow key
arzaz
How to to zap between bouquets using left and right arrow key?
Currently the left and right arrow key can only zap between channels for the same bouquet.
Please your help
Please post which image you're using, and which model VU+.
Usually, to zap between bouquets, you bring up your channels list, by pressing the centre up/down buttons, then zap using the two buttons, to the right of the centre console.
When in the channel list you can also see options to navigate using your coloured buttons, Blue - Favourites, Red - All, Green - Satellites, Yellow - Providers.
Dear Mick12334
BH image 3.0.8 C
VU+ UNO 4K SE
My question is how to naviagte in my favourites lists (Movie - Music - News Sport...) using the centre left/right buttons without using the coloured buttons?
Example: On Movie list when pressing the centre up/down i can zap only the channels of the Movie list and i cannot move to Sport list using the left/right arow key i have to use the blue button to move the rquired list.
Try using the channel + and - buttons, when viewing your channel list.
My VU+ Duo 2 has a different style remote control, with the volume +/-, and the channel +/- buttons being sited to the left, and right, of the centre control.
Dear Mick12334
BH image 3.0.8 C
VU+ UNO 4K SE
It seems you are creating your bouquets the wrongest way! Are you creating them by genres instead of providers? If so, is impossible to do what you are intending :(
@nunigia ,
Why not (or you did not understand the question)
You can give a bouquet any name and put the channels, you want.
Let's say bouquet movie channels , with movie channels.
The problem for the user is that he wants a different use of the buttons
and it's another story..
Some users like this and others different again.
Everything has its advantages and disadvantages.
In the Black Hole, the function of the buttons can not be changed
in a simple way.
bouquets can be changed with channel + -
But I never use it
I prefer the way it is.I think that's a matter of habit.
Now we have buttons in the center for the navigation inside the bouquet
What is very practical with a bouquet with many channels,
And to navigate in the list of bouquets,which is also very long if you have many satellites/bouquets.
