Zapping problem
ab9adr
Hi every one, I have a problem with my VU+ Solo, actually when I am watching a channel, and I want to switch to another I sometimes have an error message. This message appear frequently and can be seen in every channel. So I have to go to an other channel and come back more than one time to see the channel . I whish that someone can help me :)
Can you give more info ? What satellite, what channels, which image version do you use, what is your sat configuration ?
the problem can affect all the channels in all satellites, I use The BH 1.6.3 image, the problem is the same in all the other images (VTI, old BH images and also in the official one). I have 4 satelites and I use a rotating dish with a v-box
I think you must verify dish pointment before do other image tests.
Lets have a shut of your Tuner settings (reception settings)!
And Like 2know do U use a DiSEqC?
Ok , here is my settings, we may have the same SATs,,,,,,;)!
This 4LNB1 and
4LNB2 change "committed DiSEqC commend>>>>>>> AB.
4LNB3 change "committed DiSEqC commend>>>>>>> BA.
4LNB4 change "committed DiSEqC commend>>>>>>> BB,
etc,,,,,!
or Go as per your DiSEqC.....sequence (ترتيب)!
change the input 1,,,,,to 4 as per LNB # for uncommitted DiSEqC for #INPUT.
Have Fun w/BHI.
Thanks a911, I tried what you suggested me but the dish doesn't rotate automaticaly anymore when I switch to DISEqc 2 it works but always the same problem :s
Will, I only have 2 dishes...one for 26e,13e,7w,,,,and the other for 19.2e,,,!
And all works perfectly!
Now am sure your problem is a setting issue,,,as I see from your settings above the sequence of LNB is not like mine!
So do not follow my same setting exactly, try to adjust to yours!
شوية صبر ومحاولات وحتنحل المشكلة إنشاء الله
So do not follow my same setting try to adjust to yours!
I tried a lot of different settings. I tried also not to use my V-box and to connect the cable directly to the Vu+ but also the same problem, I also tried an other dish that I have and the same thing :confused:
