Zapping through IPTV channels?
riom
Hi,
I have added some IPTV Channels in a bouquet using dreambox edit and when i try to zap through each channel using the left and right arrow (on the remote) it doesn't switch channel instantly. I am having to double tap on the arrow to get to the next channel for some reason. Quite annoying. Is there anyway around this?
thanks
Hi, I did not know you could add IPTV.. how do I do that? I have an iptv set top box and it would be great to watch iptv on my Vu solo SE..
Hi, you need to use Dreambox Edit. You just right click inside a channel list at select Add IPTV channel. I still can't figure out how to channel zap seamlessly though. I'm using the blackhole image, maybe there's another image that works better for this
