Zero
Hi all
Can you put kodi on a vu+Zero with openvix image running
Cheers
Zero can't handle KODI. You can give a try to KodiDirect plugin.
Note that we don´t support OpenVIX images, although doesn't matter the image you are using on your Zero STB, you''ll never get Kodi to work in it, due to software and hardware limitations.
Bonjour tout le monde.
J'ai un vu+ zéro que j'utilise sous l'image Black hole 3.0.3.
Mon problème, c'est que je dois à chaque démarrage relancer le réseau. svp, que dois- je faire pour configurer mon réseau une fois pour toute.
Merci
GOOOOOOOOOOOOOOOOOOOOODE
This is like this one!
*** WARNING ***
If your post " GOOOOOOOOOOOOOOOOOOOOODE " and "TYOOOOOOOOOOOOOOO" means:
-> Good and Thank you! :)
Just click "LIKE" ... and don´t write anymore anything else with " nonsense "! ;)
PLEASE STOP "SPAMMING"!
