zoom in reproductor of blackhole. How?
sergiojess
Sometimes, when i use the reproductor of blakhole for watching a film, the zoom is not right. It removes the black lines in the top and in the botton of the screen. The result is that the film is strange (not in format 16:9).
I use the menu button to change the zoom, but i get the options to change to list of archives, clear list,... but no option to change the zoom.
Is possible to change the zoom and get again the black top and botton lines to get the film in 16:9????
What button do i have to use?
If you use EMC ( Enhanced Movie Center ver 3.7.4. Beta ), yes it´s possible, but depends of the movie format. You can do this by pressing MENU > SETUP > AV SETTINGS, on playing movie --> Change --> Dispslay user content as 16:9 set it to LETTERBOX.
Best regards
I have done it. I have changed to MEDIAPLAYER2.
But i still have the same problem with the zoom.
To adjust the zoom, i must open EMC and after i can open the film with mediaplayer2 and the zoom is right. Is a workaround to get it working.
To do EMC the default player for xmbc, do i have to change it in the file plugin.py? How?
Personally i use MEDIAPLAYER2 on XBMC, and EMC to play recorded movies on my VUPLUS DUO2 ( Hard Disk - Local Files - this cause i got bootlogos of the movie i intend to play ).
I don´t use EMC like my default player on XBMC cause the skins of player.
