if I enter the details that you gave into the VU+ will it still communicate with the modem I haveI suggest to use Google DNS serverss (8.8.8.8 & 8.8.4.4). Very reliable, stables and fasts!
yep reading it off goggle right now sounds a bit complex but I willl give it a bash or if anybody has a tut that would be excellent!Yes.
It's a better solution to replace DNS server entries directly on your modem/router instead change the ones on your network devices.
Hi
You can use the number buttons (1,4,3,6) to skip forward/back the program
