Sorry administrator,
I just used that image /skin as it is the best in expressing my problem, actually I have tried different images and all with the same results.
i have posted in different places , unfortunately it was always ignored, you are my hero you are the first one that took notice, thank you.
Actually did not understand your statement about using black hole and not using it. nevertheless, If you can help me I can adjust and install the image of your choice as long it will work.
I have vu+ ultimo4k and presently BH 3.0.4.C always with default skin.
After more digging It really looks that its is problem directly in the enigma2 encoding, if I understand well from the log files seems that enigma2 does not support part of Big5 character set. Here is a part of crash report :
10646-1 enc.
unsup. Big5 subset of ISO/IEC 10646-1 enc.
could you point me to the right place to get help>
thank you
ps should i remove that previous posting or event this one from here ?
