faravahar1000
Nothing we can do.
Quap PiP is controlled by Vu+, and therefore it bypasses the perental control that we added to the BH image.
Thanks for the clear answer
Will the same problem persist in other images?
Nothing we can do.
1) You have to enable PiP first, then you enable MiniTv then it will work.Welldone job
1.After test MiniTV is not workinh anymore
2.in EPG i chose 1st language as Arabic but still showing english epg and the channel provides arabic epg as tested on other recievers
3.Quad pip not available
Any help
2) I will report it to the coders, but I suspect vu+ need to fix this
3) Quad PiP is down to vu+, but it is installed with the image, so if you don't have it, then you must have removed it.
So press blue the use the option swap servicesThanks for reply mate
Yes I enabled pip then minitv but it shows only the pip channel not the actual ch. that means the minitv is not showing other channels if changed
Yes I foumd Qpip thank you.
Still same not changing serviceSo press blue the use the option swap services
Thank you!Press and hold Blue Button, then select Activate PiP
iptv vod filmlerinde Merhaba karadelik 3.0.6 görüntü, bu özellik 3.0.5 de ileri geri geri sarmıyoruz da sizin için yardım bekliyordu.
I dont think so.Is glitch in sound using Mediaplayer fixed?
