Black Hole 3.0.7 Vu+ Uno4K SE
Ev0
Admin
Black Hole 3.0.7
What is new ?
  • Many bug fixes
  • Added new feature to let you know when an online update is avaliable
  • Changed default Skin to MX Black Sea
  • New Bootlogo
  • New default Spinner
  • Improved Wi-Fi setup
  • Added Duo4K support
  • Reintroduced Support for Solo, Duo, Uno, Ultimo and Zero
1-jpg.40798
2-jpg.40789
3-jpg.40790
4-jpg.40791
5-jpg.40792
6-jpg.40793
7-png.40794
8-jpg.40795
9-jpg.40796
10-jpg.40797
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
Thanks for support. Some VODs do stop after seconds. These files are working in other TV/Video hardware properly, so hosting is fine and me as the client are the problem using the VU Uno 4k SE with its new 3.0.7 image (3.0.6 did also not working). The only differences I could see between videos which did not working after several trials and videos which are always working was Stream 1 Codec: A52 (working) and DTS Audio (not working). But I don't know if this is the reason.
Thanks for info
That will be fixed
until then
Pls upload this file timezone.xml from my ZIP in to /etc/tuxbox/
Restart box and test.
You may need to reconfigure after Fixed in the image online update
Thanks for info
That will be fixed
until then
i replaced the xml file and now works!thanks a lot my friend!
timezone problem is fixed
Image is updated on Black Hole image server
if not already
you can update image later online.
To see if there is an image update.
You have to go in to standby and come out of standby.
After that in the 2nd OSD you will get info about whether there is an image update.
Then make the image update Green button>>yellow>>Online Black Hole image update
Black Hole 3.0.7
What is new ?
  • Many bug fixes
  • New Bootlogo
1-jpg.40798
2-jpg.40789
3-jpg.40790
4-jpg.40791
5-jpg.40792
6-jpg.40793
7-png.40794
8-jpg.40795
9-jpg.40796
10-jpg.40797
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
