Black Hole 3.0.8 - 3.0.9 - DVB-T USB not working anymore...
WebMan
Hi.
Anyone solve the problem?
We can not use the DVB-T USB tuners with ANY IMAGE greater than 3.0.7 !!!
Till (and included) 3.0.7, everything works perfect, after this.... the device are not recognized any more....
I tested in 3.0.8 and 3.0.9, without success, these tuners:
* AverVolar HD
* Sky DVB-T Blu Led
Ty
I'm surprised... probably something goes wrong on build server... Please could you tell us which box have such issue? Does you upgraded the same box or you are comparig 3.0.7 on a box and 3.0.9 on another box?
Pal. this is not a NEW PROBLEM...
I mentioned even HERE, when 3.0.8 came out, but no one avoid/resolve the problem...
So, PERSONALLY I tested the problem on:
- VU+ Solo2
- VU+ SoloSE
- VU+ Uno 4K
If you install 3.0.7 (and all update on line), the USB DVB-T Tuner works Perfect !!!!
If you use 3.0.8 or 3.0.9 the DVB-T Tuner doesn0t work any more !!!! (even with all updates)...
So, I believe, 99% of Italian users doesn't use anymore BlackHole (new versions), or, in my case, spend 70 € (but there are not many) to buy an VU+ DVB-T Turbo tuner....
So... no one have solution...
No one are interesting to solve the problem.... so, I put other question:
It is possible to save the drivers from 3.0.7 and put to 3.0.9 ?
If so, where are located ?
Thank you...
live post... keep reading
going to test on uno4k..
-installed 3.0.9.. then live update.... just an enigma2 update.., rebooted
plugged in vu+turbo..
[ 28.948795] usb 4-1: dvb_usb_v2: 'Vu+ Tuner : Vuplus DVB-T/C USB NIM(TURBO)' successfully initialized and connected
scanning (442 services)
i can open channel...
plugging in sky blue...
[ 3.555112] usb 4-1: bh_dvb_usb_v2: 'AVerMedia HD Volar (A867)' successfully initialized and connected
started a new scan... just to be sure... it found some channel but it take ages so i'm going to stop on the first transponder.
plugging in sky green...
[ 197.676636] Registered device Sky IT Digital Key (green led)
[ 197.682250] usbcore: registered new interface driver Abilis Systems as10x usb driver
--- there is an issue since vuplus remote stop working -- will fix
plugging avermedia a850
[ 3.263965] usb 4-1: bh_dvb_usb_v2: 'AverMedia AVerTV Volar Black HD (A850)' successfully initialized and connected
plugging in hauppauge ministick
[ 184.104464] usb 4-1: DVB: registering adapter 1 frontend 0 (Siano Mobile Digital MDTV Receiver)...
[ 184.115254] usbcore: registered new interface driver smsusb
plugging in hauppauge nova td
[ 266.397858] dvb-usb: Hauppauge Nova-TD Stick (52009) successfully initialized and connected.
[ 266.406575] usbcore: registered new interface driver dvb_usb_dib0700
plugging in unknown 820t2 &sdr (raphael micro)
[ 854.887878] usb 4-1: bh_dvb_usb_v2: 'Realtek RTL2832U reference design' successfully initialized and connected
[ 854.899142] usbcore: registered new interface driver dvb_usb_rtl28xxu
plugging in unknown hdtv usb dvb-t
it9135, detected but doesn't work... will check
unknown device (e4000)
[ 950.081032] usb 4-1: bh_dvb_usb_v2: schedule remote query interval to 400 msecs
[ 950.099818] usb 4-1: bh_dvb_usb_v2: 'Realtek RTL2832U reference design' successfully initialized and connected
[ 960.773992] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
plugging in xbox tv tuner...
can't work in this kernel
I suppose that who got the issue have flashed the new image with the usb-tuner connected.
People should disconnct it when flashing, as when the tuner may load before the internal tuner and make you to have unexpected issue (eg, the tuner helper may not recognize the usb tuner in the expected location)
Hi.
* AverVolar HD
* Sky DVB-T Blu Led
Ty
Hello,
Recently I have noticed a similar problem as you described.
I tried various configurations with no success until I did it as follows:
1) Switch to the DVB-S channel
2) System Shutdown
3) Disconnect DVB-T head (unplug from USB port)
4) Launch Black Hole (without DVB-T)
5) "online update"
6) Restart Black Hole (still without DVB-T)
7) Shutdown Black Hole
8) Connect the DVB-T head (with the device turned off)
9) Launch Black Hole
10) Do the re-settings of the DVB-T head (it appeared but as DVB-S, so you have to enter the settings and switch to DVB-T)
11) Restart Black Hole and everything works!
Best Regards
Hi.
* AverVolar HD
* Sky DVB-T Blu Led
Ty
Please try the 3.0.9.N version
http://www.vuplus-community.net/board/forums/black-hole-images-download.156/
Driverupdate.
BlackHole-Team has startet to "downport" more usbtuner-driver goodies from higher Linux versions.
What was broken in the 3.0.9.L+ version, is "somehow/almost" ok again in the 3.0.9.N version.
Best regards
Hi
I own a vu solo2 flashed with blackhole 3.0.9N and dvb T2 mygica T230c dos not work.
Could you please help me.
Farid
additional
root@vusolo2:~# dmesg | grep usb
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usb 2-1: new high-speed USB device number 2 using ehci-brcm
usb 2-1: config 1 interface 0 altsetting 0 bulk endpoint 0x86 has invalid maxpacket 188
usb 2-1: string descriptor 0 malformed (err = -61), defaulting to 0x0409
additional
I plan to add support for t330. Probably I will support this tuner as well
