Black Hole 3.0.8 - 3.0.9 - DVB-T USB not working anymore...
Green Button - Yellow Button - Online Black Hole Image Update
Hi,
Thanks, for your support. I already did that, I installed bh3.0.9N and did online update and switch off the receiver, plug in the dvb, switch on the receiver but nothing happen. I still have the same msg as before on dmesg.
it
Hi,
It look like the module don't load.
root@vusolo2:~# dmesg | grep usb
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usb-storage 1-1:1.0: USB Mass Storage device detected
scsi2 : usb-storage 1-1:1.0
usb 2-1: new high-speed USB device number 2 using ehci-brcm
usb 2-1: config 1 interface 0 altsetting 0 bulk endpoint 0x86 has invalid maxpacket 188
usb 2-1: string descriptor 0 malformed (err = -61), defaulting to 0x0409
root@vusolo2:~# lsmod
Module Size Used by
ipv6 332460 26
ext2 57304 0
brcmfb 1590 3
dvb_bcm7356 1462720 30 brcmfb
dvb_base 4584201 187 dvb_bcm7356
bcm_event 2990 5 dvb_bcm7356
procmk 1668 2 dvb_bcm7356,bcm_event
root@vusolo2:~#
hi any news on that
these are from open blackhole if it help
root@vusolo2:~# lsusb
Bus 001 Device 002: ID 090c:1000
Bus 002 Device 002: ID 0572:c688
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0002
Bus 005 Device 001: ID 1d6b:0001
Bus 006 Device 001: ID 1d6b:0001
Bus 007 Device 001: ID 1d6b:0001
Bus 008 Device 001: ID 1d6b:0001
Module Size Used by
tun 20106 2
ipv6 375648 80
brcmfb 1590 3
dvb_bcm7356 1462720 29 brcmfb
si2157 4996 1
si2168 7416 1
i2c_mux 1862 1 si2168
dvb_usb_dvbsky 10814 2
dvb_usb_v2 14893 1 dvb_usb_dvbsky
xfs 679463 0
libcrc32c 714 1 xfs
root@vusolo2:~# modinfo dvb_usb_dvbsky
filename: /lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-dvbsky.ko
license: GPL
description: Driver for DVBSky USB
author: Max nibble <nibble.max@gmail.com>
alias: usb:v0572pC688d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0572pC689d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0572pC68Ad*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0B48p3012d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0B48p3014d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0572p0320d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0572p680Cd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0572p960Cd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0572p6831d*dc*dsc*dp*ic*isc*ip*in*
depends: dvb_usb_v2
intree: Y
vermagic: 3.13.5 SMP mod_unload BMIPS 32BIT
parm: disable_rc:Disable inbuilt IR receiver. (int)
parm: adapter_nr:DVB adapter numbers (array of short)
these alias are missing in blackhole image
and the dependency between si2168 and i2c-mux
could yu please let men know if i can add them by command line or by a config file in depmod.d
Thanks
i solved the problem with my hauppage wintv dual dvbt installing the drivers firmware-dvb-usb-dib0700-1.20_1.1+git292+25f936b-r0_all.ipk and restart my vu+uno 4k se.
link here --> EXTERNAL LIVE LINKS NOT ALLOWED ON OUR BOARD
