stream tv player not working crach
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Fri Nov 14 15:38:08 2014</crashdate>
<compiledate>Nov 13 2014</compiledate>
<contactemail>crashlog</contactemail>
<skin>skin.xml</skin>
<sourcedate>2014-11-13</sourcedate>
<branch>master</branch>
<rev>a98ed72</rev>
<version>3.0.0</version>
</enigma2>
<image>
<dreamboxmodel>dm500hd</dreamboxmodel>
<kernelcmdline>bmem=156M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201411130943
</imageversion>
<imageissue>
<![CDATA[
BlackHole 2.1.3 %h
</imageissue>
</image>
<software>
<enigma2software>
<!-- Cannot allocate memory -->
</enigma2software>
<dreamboxsoftware>
</dreamboxsoftware>
<gstreamersoftware>
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
g BlackHoleapi handler
starting hotplug handler
It's now Thu Jan 1 01:07:18 1970
[timer.py] next activation: 538 (in 99898 ms)
timers.xml not found!
[timer.py] next activation: 538 (in 99882 ms)
[CrossEPG_Auto] AutoStart Enabled
[CrossEPG_Auto] Schedule Disabled at Thu Jan 1 01:07:18 1970
[EPGC] setCacheFile read/write epg data from/to '/hdd/epg.dat'
not showing fine-tuning wizard, config variable doesn't exist
showtestcard is false
Looking for embedded skin
setValue 100
Setvolume: 100 100 (raw)
Setvolume: 0 0 (-1db)
allocating new converter!
main thread is non-idle! display spinner!
resolve: resolve ${datadir}/enigma2/%s/
resolve: -> /usr/share/enigma2/%s/
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
RemovePopup, id = ZapError
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
child has terminated
pipes closed
pipes closed
[ePopen] command: route -n | grep eth0
poll: unhandled POLLERR/HUP/NVAL for fd 30(16)
poll: unhandled POLLERR/HUP/NVAL for fd 32(17)
pipes closed
0.0.0.0
169.254
192.168
nameservers: [[192, 168, 2, 254], [195, 241, 77, 55], [195, 241, 77, 58]]
read configured interface: {'lo': {'dhcp': False}, 'eth0': {'dhcp': True}}
self.ifaces after loading: {'eth0': {'preup': False, 'predown': False, 'ip': [192, 168, 2, 1], 'up': True, 'mac': '00:1d:ec:02:10:5b', 'dhcp': True, 'bcast': [192, 168, 2, 255], 'netmask': [255, 255, 255, 0], 'gateway': [192, 168, 2, 254]}}
AT plugin not found
ER plugin not found
resolve: resolve ${libdir}/enigma2/python/Plugins/Extensions/WebInterface/plugin.py
resolve: -> /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/plugin.py
resolve: resolve ${libdir}/enigma2/python/Plugins/Extensions/OpenWebif/pluginshook.src
resolve: -> /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/pluginshook.src
[OpenWebif] no plugins to load
[OpenWebif] started on 80
action -> OkCancelActions ok
action -> ChannelSelectBaseActions showSatellites
eStaticServiceDVBBouquetInformation::getName failed.. getBouquet failed!
playing service..
not pauseable.
allocate channel.. 022b:02be
opening frontend 0
[eDVBCAService] new channel 0x1dc4e10!
(0)tune
Entry for 26,0? not in Rotor Table found... i try gotoXX?
siteLatitude = 50.766998, siteLongitude = 5.100000, 26.000000 degrees
PolarmountHourAngle=156.957234
RotorCmd = e170
RotorCmd e170, lastRotorCmd ffffffff
set rotor timeout to 360 seconds
prepare_sat System 1 Freq 12245000 Pol 1 SR 27500000 INV 2 FEC 4 orbpos 260 system 1 modulation 1 pilot 2, rolloff 2
tuning to 1645 mhz
OURSTATE: tuning
allocate Channel: res 0
[eDVBCIInterfaces] addPMTHandler 1:0:1:3:22B:2BE:1040000:0:0:0:
allocate demux
resolve: resolve ${sysconfdir}/scan_tp_valid_check.py
resolve: -> /etc/scan_tp_valid_check.py
[SEC] set static current limiting
set sequence pos 3
[SEC] setVoltage 1
[SEC] sleep 900ms
set sequence pos 9
[SEC] invalidate current rotorparams
[SEC] sendDiseqc: e0316ee170
[SEC] sleep 1000ms
action -> GlobalActions volumeDown
Setvolume: 95 95 (raw)
Setvolume: 4 4 (-1db)
setValue 95
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 0
setting frontend 0
[SEC] set timeout 1440
[SEC] sleep 250ms
Setvolume: 90 90 (raw)
Setvolume: 7 7 (-1db)
setValue 90
[SEC] rotor locked step 0 failed (not locked)
set sequence pos -3
[SEC] sleep 250ms
Setvolume: 85 85 (raw)
Setvolume: 10 10 (-1db)
setValue 85
[SEC] locked step 0 ok
set sequence pos -3
[SEC] sleep 250ms
Setvolume: 80 80 (raw)
Setvolume: 13 13 (-1db)
setValue 80
Setvolume: 75 75 (raw)
Setvolume: 16 16 (-1db)
setValue 75
[SEC] locked step 1 ok (305419896 305419896)
set sequence pos -3
[SEC] sleep 250ms
Setvolume: 70 70 (raw)
Setvolume: 19 19 (-1db)
setValue 70
[SEC] locked step 2 ok (305419896 305419896)
set sequence pos -3
[SEC] sleep 250ms
Setvolume: 65 65 (raw)
Setvolume: 23 23 (-1db)
setValue 65
[SEC] locked step 3 ok (305419896 305419896)
set sequence pos -3
[SEC] sleep 250ms
Setvolume: 60 60 (raw)
Setvolume: 26 26 (-1db)
setValue 60
Setvolume: 55 55 (raw)
Setvolume: 29 29 (-1db)
setValue 55
[SEC] locked step 4 ok (305419896 305419896)
ok > 4 .. goto 3
set sequence pos 3
OURSTATE: ok
[eDVBCAService] channel 0x1dc4e10 running
[eDVBLocalTimerHandler] channel 0x1dc4e10 running
no version filtering
0014: 70 00 00 00 00 00
mask: fc 00 00 00 00 00
mode: 00 00 00 00 00 00
[eEPGCache] channel 0x1dc4e10 running
stop release channel timer
0012: 4e 00 03 00 00 00
mask: ff ff ff 00 00 00
ok ... now we start!!
0000: 00 00 00 00 00 00
mask: ff 00 00 00 00 00
[SEC] update current rotorparams 1434 e170 260
set sequence pos 4
[SEC] update current switch params
[SEC] sleep 500ms
+ 1/1 TID 00
done!
PATready
use pmtpid 006e for service_id 0003
006e: 02 00 03 00 00 00
doing version filtering
0000: 00 00 00 07 00 00
mask: ff 00 00 3f 00 00
mode: 00 00 00 3e 00 00
Setvolume: 50 50 (raw)
Setvolume: 32 32 (-1db)
setValue 50
+ 1/1 TID 02
done!
eventNewProgramInfo 0 0
have 1 video stream(s) (00d2), and 2 audio stream(s) (0136, 019a), and the pcr pid is 00d2, and the text pid is ffffffff
allocate demux
disable teletext subtitles
PES filter: DMX_SET_PES_FILTER - Invalid argument
decoder state: play, vpid=210, apid=310
DMX_SET_PES_FILTER(0xd2) - pcr - ok
DEMUX_START - pcr - ok
DMX_SET_PES_FILTER(0x136) - audio - ok
DEMUX_START - audio - ok
AUDIO_SET_BYPASS(1) - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
Video Device: /dev/dvb/adapter0/video0
demux device: /dev/dvb/adapter0/demux0
VIDEO_SET_STREAMTYPE 1 - ok
DMX_SET_PES_FILTER(0xd2) - video - ok
DEMUX_START - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
VIDEO_SLOWMOTION(0) - ok
VIDEO_FAST_FORWARD(0) - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
AUDIO_CHANNEL_SELECT(0) - ok
not pauseable.
[eDVBCAService] new service 1:0:1:3:22B:2BE:1040000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:3:22B:2BE:1040000:0:0:0:
[eDVBCIInterfaces] gotPMT
demux 0 mask 01 prevhash 00000000
006e: 02 00 03 05 00 00
mask: ff ff ff 3f 00 00
Setvolume: 45 45 (raw)
Setvolume: 35 35 (-1db)
setValue 45
Setvolume: 40 40 (raw)
Setvolume: 38 38 (-1db)
setValue 40
[eDVBLocalTimerHandler] dont have correction.. set Transponder Diff
[eDVBLocalTimerHandler] update RTC
[eDVBLocalTimerHandler] time update to 15:37:44
[eDVBLocalTimerHandler] m_time_difference is 1415975386
[eDVBLocalTimerHandler] set Linux Time
[EPGC] time updated.. start EPG Mainloop
before: 1
after: 1
VIDEO_GET_EVENT - ok
[EPGC] next update in 2 sec
[SEC] set dynamic current limiting
Setvolume: 35 35 (raw)
Setvolume: 41 41 (-1db)
setValue 35
sdt update done!
Setvolume: 30 30 (raw)
Setvolume: 45 45 (-1db)
setValue 30
action -> GlobalActions volumeUp
setValue 35
setValue 30
[EPGC] start caching events(1415975866)
timeout 0012!
action -> InfobarMenuActions mainMenu
loading mainmenu XML...
BhRed BhRedp_main
BhSettings DeliteSettings
PluginBrowser PluginBrowser
BhAddons DeliteAddons
BhEpgPanel DeliteEpgPanel
TimerEdit TimerEditList
reused converter!
reused converter!
reused converter!
okbuttonClick
Ci CiSelection
ParentalControlSetup ParentalControlSetup
reused converter!
reused converter!
reused converter!
okbuttonClick
LanguageSelection LanguageSelection
NetworkSetup NetworkAdapterSelection
reused converter!
reused converter!
reused converter!
[EPGC] abort non avail nownext reading
[EPGC] abort non avail schedule reading
[EPGC] abort non avail schedule other reading
[EPGC] abort non avail viasat reading
[EPGC] abort non avail mhw reading
okbuttonClick
reused converter!
reused converter!
reused converter!
action -> SetupActions right
unknown action SetupActions/right! typo in keymap?
set aspect, policy, policy2, wss 16:9 bestfit letterbox auto
set aspect, policy, policy2, wss 16:9 bestfit bestfit auto
action -> SetupActions save
action -> OkCancelActions cancel
action -> InfobarShowHideActions hide
action -> InfobarSubserviceSelectionActions DeliteGpshow
reused converter!
reused converter!
reused converter!
warning, skin is missing element key_yellow in <class 'Blackhole.BhGreen.DeliteGreenPanel'>
warning, skin is missing element key_blue in <class 'Blackhole.BhGreen.DeliteGreenPanel'>
warning, skin is missing element key_green in <class 'Blackhole.BhGreen.DeliteGreenPanel'>
warning, skin is missing element key_red in <class 'Blackhole.BhGreen.DeliteGreenPanel'>
no ancillary data in audio stream... abort radiotext pes parser
action -> WizardActions down
unknown action WizardActions/down! typo in keymap?
action -> WizardActions ok
reused converter!
reused converter!
reused converter!
warning, skin is missing element infolabel in <class 'Plugins.Extensions.StreamTV.plugin.StreamTVList'>
warning, skin is missing element infomation in <class 'Plugins.Extensions.StreamTV.plugin.StreamTVList'>
File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
res = self.actions[action]()
File "/usr/lib/enigma2/python/Blackhole/BhGreen.py", line 44, in save
File "/usr/lib/enigma2/python/Blackhole/BhGreen.py", line 50, in run
File "/usr/lib/enigma2/python/Plugins/Extensions/StreamTV/plugin.py", line 353, in main
session.open(StreamTVList)
File "/usr/lib/enigma2/python/mytest.py", line 312, in open
dlg = self.current_dialog = self.instantiateDialog(screen, *arguments, **kwargs)
File "/usr/lib/enigma2/python/mytest.py", line 247, in instantiateDialog
return self.doInstantiateDialog(screen, arguments, kwargs, self.desktop)
File "/usr/lib/enigma2/python/mytest.py", line 278, in doInstantiateDialog
dlg.applySkin()
File "/usr/lib/enigma2/python/Components/GUISkin.py", line 112, in applySkin
self.createGUIScreen(self.instance, self.desktop)
File "/usr/lib/enigma2/python/Components/GUISkin.py", line 47, in createGUIScreen
f()
File "/usr/lib/enigma2/python/Plugins/Extensions/StreamTV/plugin.py", line 248, in layoutFinished
rc = os.popen('ps -ef | grep rtmpdump | grep -v grep').read()
OSError: [Errno 12] Cannot allocate memory
(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x1d51918>>,('WizardActions', 'ok')) failed)
</enigma2crashlog>
<pythonMD5sum>
</pythonMD5sum>
</crashlogs>
</opendreambox>
ts pannel cannot instal
not working back too 211
<opendreambox>
<enigma2>
<crashdate>Sat Nov 15 08:39:56 2014</crashdate>
<rev>a98ed72</rev>
</enigma2>
<image>
<imageversion>
<![CDATA[
</imageversion>
<imageissue>
<![CDATA[
BlackHole 2.1.3 %h
</imageissue>
</image>
<software>
<enigma2software>
</enigma2software>
<dreamboxsoftware>
</dreamboxsoftware>
<gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
: -> /usr/lib
[MeoBoot] set language to en
[MeoBoot] fallback to default translation for E2 Light Multiboot
<ZappingModeSelection> set zapping mode : mute
resolve: resolve ${sysconfdir}/enigma2/
resolve: -> /etc/enigma2/
--> setting contrast to: 00008000
--> setting saturation to: 00008000
--> setting hue to: 00008000
--> setting brightness to: 00008000
--> setting block_noise_reduction to: 00000000
--> setting mosquito_noise_reduction to: 00000000
--> setting digital_contour_removal to: 00000000
--> setting splitmode to: off
--> setting sharpness to: 00000000
--> setting auto_flesh to: 00000000
--> setting green_boost to: 00000000
--> setting blue_boost to: 00000000
--> setting dynamic_contrast to: 00000000
--> applying pep values
[AutoShutDown] set language to en
[AutoShutDown] fallback to default Enigma2 Translation for Standby
[AutoShutDown] fallback to default Enigma2 Translation for Deepstandby
[AutoShutDown] fallback to default Enigma2 Translation for AutoShutDown Setup
remove DVI-PC because it does not exist.
hotplug on DVI
set Videomode DVI 1080i multi
set aspect, policy, policy2, wss 16:9 panscan letterbox auto
[CI_Assignment] activating ci configs:
[CI_Activate] FOUND 2 CI Slots
resolve: resolve ${sysconfdir}/enigma2/ci
resolve: -> /etc/enigma2/ci
[CI_Activate_Config_CI0] no config file found
[CI_Activate_Config_CI0] error parsing xml...
[CI_Activate_Config_CI1] no config file found
[CI_Activate_Config_CI1] error parsing xml...
starting BlackHoleapi handler
It's now Sat Nov 15 08:37:05 2014
[timer.py] next activation: 1416037125 (in 99818 ms)
[timer.py] next activation: 1416037125 (in 99732 ms)
[CrossEPG_Auto] Schedule Disabled at Sat Nov 15 08:37:05 2014
[AutoShutDown] start....
port changed to DVI
mode changed to 1080i
default ('1080i', 'default')
preferedmodes ['720p', '576p', '480p', '576i', '480i', ('1080i', 'default')]
before: 1
after: 1
setValue 100
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
[EPGC] 2382 events read from /hdd/epg.dat
reused converter!
[EPGC] start cleanloop
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
[EPGC] stop cleanloop
[EPGC] 343390 bytes for cache used
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
playing service..
not pauseable.
allocate channel.. 0446:0001
opening frontend 0
[eDVBCAService] new channel 0x1956c58!
(0)tune
RotorCmd ffffffff, lastRotorCmd ffffffff
prepare_sat System 1 Freq 12285000 Pol 1 SR 29700000 INV 2 FEC 2 orbpos 192 system 1 modulation 2 pilot 2, rolloff 1
tuning to 1685 mhz
OURSTATE: tuning
[eDVBCIInterfaces] addPMTHandler 1:0:1:428A:446:1:C00000:0:0:0:
allocate demux
[SEC] invalidate current switch params
[SEC] setVoltage 1
[SEC] sleep 10ms
pipes closed
pipes closed
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] startTuneTimeout 5000
[SEC] setFrontend 1
setting frontend 0
[SEC] sleep 500ms
(0)fe event: status 0, inversion off, m_tuning 1
pipes closed
0.0.0.0
169.254
192.168
nameservers: [[192, 168, 1, 1]]
read configured interface: {'lo': {'dhcp': False}, 'eth0': {'dhcp': False, 'netmask': [255, 255, 255, 0], 'gateway': [192, 168, 1, 1], 'address': [192, 168, 1, 103]}}
self.ifaces after loading: {'eth0': {'preup': False, 'predown': False, 'ip': [192, 168, 1, 103], 'up': True, 'mac': '00:1d:ec:04:71:b4', 'dhcp': False, 'netmask': [255, 255, 255, 0], 'gateway': [192, 168, 1, 1]}}
AT plugin not found
ER plugin not found
poll: unhandled POLLERR/HUP/NVAL for fd 31(16)
(0)fe event: status 1f, inversion off, m_tuning 2
OURSTATE: ok
[eDVBCAService] channel 0x1956c58 running
[eDVBLocalTimerHandler] channel 0x1956c58 running
[eEPGCache] channel 0x1956c58 running
0012: 4e 42 8a 00 00 00
have 1 video stream(s) (0086), and 1 audio stream(s) (014e), and the pcr pid is 0086, and the text pid is 027a
allocate demux
decoder state: play, vpid=134, apid=334
DMX_SET_PES_FILTER(0x86) - pcr - ok
DMX_SET_PES_FILTER(0x14e) - audio - ok
AUDIO_SET_BYPASS(0) - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
DMX_SET_PES_FILTER(0x86) - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
DMX_SET_PES_FILTER(0x27a) - ttx - ok
DEMUX_START - ttx - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
not pauseable.
[AutoRes] service changed
-+ 1/2 TID 4e
+ 1/1 TID 00
done!
PATready
use pmtpid 0342 for service_id 428a
0342: 02 42 8a 00 00 00
0000: 00 00 00 2f 00 00
[AutoRes] got event evVideoSizeChanged
+ 1/1 TID 02
done!
[eDVBCAService] new service 1:0:1:428A:446:1:C00000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:428A:446:1:C00000:0:0:0:
0342: 02 42 8a 03 00 00
[AutoRes] got event evFramerateChanged
++ 2/2 TID 4e
done!
0012: 4e 42 8a 23 00 00
[AutoRes] got event evVideoProgressiveChanged
sdt update done!
[AutoRes] determineContent
[AutoRes] switch deinterlacer mode to auto
[AutoRes] new content is 1920x1080p25
[AutoRes] determined videomode 1080i
[EPGC] start caching events(1416037037)
[eDVBLocalTimerHandler] diff is 3
[eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
[eDVBLocalTimerHandler] time update to 08:37:21
[eDVBLocalTimerHandler] m_time_difference is 3
[EPGC] 353971 bytes for cache used
[EPGC] nownext finished(1416037046)
[eDVBCAService] send 524 bytes
9f 80 32 82 02 06 03 42 8a 03 00 13 01 81 08 00 c0 00 00 04 46 00 01 82 02 01 00 84 02 03 42 1b 00 86 00 e5 01 09 07 18 11 e9 82 02 33 11 09 07 18 11 e9 e6 02 33 17 09 07 18 19 e8 ba 02 00 6d 09 0f 05 00 e4 0a 10 01 01 13 01 20 14 03 03 29 48 09 0f 05 00 e4 6e 10 01 01 13 01 20 14 03 03 29 28 09 0f 05 00 e5 36 10 01 01 13 01 20 14 03 03 28 38 09 0f 05 00 e5 fe 10 01 01 13 01 20 14 03 04 28 08 09 0f 05 00 e6 62 10 01 01 13 01 20 14 03 04 28 28 09 0f 05 00 e7 f2 10 01 01 13 01 20 14 03 04 33 38 09 07 18 63 ea 4a 02 33 42 09 07 18 63 eb 12 02 33 43 09 0f 05 00 e7 2a 10 01 00 13 01 20 14 03 05 19 08 09 3e 01 00 e9 1e a8 21 ff ff ff ff ff ff ff ff ff 00 21 e9 82 33 11 ff 7f ff ff ff ff ff ff ff 00 21 e9 e6 33 17 ff 7f ff ff ff ff ff ff ff 00 21 e8 ba 00 6d ff ff ff ff ff ff ff ff ff 0c 21 06 02 7a 00 00 06 01 4e 00 e5 01 09 07 18 11 e9 82 02 33 11 09 07 18 11 e9 e6 02 33 17 09 07 18 19 e8 ba 02 00 6d 09 0f 05 00 e4 0a 10 01 01 13 01 20 14 03 03 29 48 09 0f 05 00 e4 6e 10 01 01 13 01 20 14 03 03 29 28 09 0f 05 00 e5 36 10 01 01 13 01 20 14 03 03 28 38 09 0f 05 00 e5 fe 10 01 01 13 01 20 14 03 04 28 08 09 0f 05 00 e6 62 10 01 01 13 01 20 14 03 04 28 28 09 0f 05 00 e7 f2 10 01 01 13 01 20 14 03 04 33 38 09 07 18 63 ea 4a 02 33 42 09 07 18 63 eb 12 02 33 43 09 0f 05 00 e7 2a 10 01 00 13 01 20 14 03 05 19 08 09 3e 01 00 e9 1e a8 21 ff ff ff ff ff ff ff ff ff 00 21 e9 82 33 11 ff 7f ff ff ff ff ff ff ff 00 21 e9 e6 33 17 ff 7f ff ff ff ff ff ff ff 00 21 e8 ba 00 6d ff ff ff ff ff ff ff ff ff 0c 21 c0 00 d0 00 00 c1 00 cd 00 00 c1 04 e5 00 00 ff 03 9e 00 00
[AutoRes] new content is 1920x1080i25
[EPGC] schedule finished(1416037069)
[EPGC] stop caching events(1416037069)
[EPGC] next update in 60 min
[EPGC] 429263 bytes for cache used
It's now Sat Nov 15 08:38:47 2014
[timer.py] next activation: 1416037227 (in 99994 ms)
[timer.py] next activation: 1416037227 (in 99992 ms)
BhRed BhRedp_main
reused converter!
reused converter!
reused converter!
okbuttonClick
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
File "/usr/lib/enigma2/python/Blackhole/BhSettings.py", line 1437, in updateFeed2
File "/usr/lib/enigma2/python/Blackhole/BhSettings.py", line 1451, in updateList
File "/usr/lib/enigma2/python/Blackhole/BhSettings.py", line 1467, in checkInst
IOError: [Errno 2] No such file or directory: '/tmp/bhspeed.tmp'
(PyObject_CallObject(<bound method BhSpeedUp.updateFeed2 of <class 'Blackhole.BhSettings.BhSpeedUp'>>,()) failed)
</enigma2crashlog>
<pythonMD5sum>
</pythonMD5sum>
</crashlogs>
</opendreambox>
Hi have this working but no HD coming through
any thoughts
When I try to "Blackhole speed up", the system crashes. Here is the crash log.
<opendreambox>
<enigma2>
<rev>a98ed72</rev>
</enigma2>
<image>
<imageversion>
<![CDATA[
</imageversion>
<imageissue>
<![CDATA[
BlackHole 2.1.3 %h
</imageissue>
</image>
<software>
<enigma2software>
</enigma2software>
<dreamboxsoftware>
</dreamboxsoftware>
<gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
: -> /usr/lib
hotplug on DVI
port changed to DVI
before: 1
after: 1
setValue 100
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
playing service..
not pauseable.
opening frontend 0
(0)tune
tuning to 1685 mhz
OURSTATE: tuning
allocate demux
[SEC] setVoltage 1
[SEC] sleep 10ms
pipes closed
pipes closed
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 1
setting frontend 0
[SEC] sleep 500ms
pipes closed
0.0.0.0
169.254
192.168
AT plugin not found
ER plugin not found
OURSTATE: ok
allocate demux
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
not pauseable.
-+ 1/2 TID 4e
+ 1/1 TID 00
done!
PATready
+ 1/1 TID 02
done!
++ 2/2 TID 4e
done!
sdt update done!
BhRed BhRedp_main
reused converter!
reused converter!
reused converter!
okbuttonClick
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
</enigma2crashlog>
<pythonMD5sum>
</pythonMD5sum>
</crashlogs>
</opendreambox>
have loaded file onto usb and put into machineExplain better please.
channels are there and non HD channels are on even if usb is out but nothing comes on screen if we choose a hd channel am I missing something havent used the machine for a long time and forgotten what we do with it tbh lol
I tried extensions from software manager like flashexpander and others , i can't insatlling on Vu+solo on 2.1.2 work perfectWhat extensions?
