BlackHole 3.1.0 Multistream Vu+ Zero4K
WOW: so you found out an incredible bug no one else has found out, yet.
So, nobody has ever been able to mount their HDD and record on it! Very useless PVR are these boxes, according to you, if BH can't use HDDs.
And if you say "still" it means this very big issue was already existing in the previous versions.
But, strangely enough, I've always been able to mount HDDs.
Unless you mean you had problem under a BH install under OMB (but you did not specify anything, of course: just 8 words to describe an issue.
Had an older version on my box and the hdd never worked, updated to 3.1 and hdd still doesn't work.
Hdd remains in standby, even the timer is set to zero. Hdd refuses to mount.
I use devicemanager to set mountpoints what i try hdd stays in standby/no mount.
