Changing only splash screen
AlexWilMac
Moderator
Is it possible to change just the splash screen without reflashing the STB?
And can someone post the original HD splash screen of VU+Duo2?
Thanks!
Eragon
Vu+ User+++
Yes, put only a splash_cfe_auto.bin file in the duo2 folder (remove all other files) and flash as usual.
The flashing will last only few seconds.
You can extract the file from any original Vu+ Duo2 image.
Eragon
Vu+ User+++
The image resolution, format (bmp), color depth and final dimension (bytes) must be the same as the original file.
Moderator
Just for knowing
All the spashscreens i saw, on severall images, are resolution 720x576 px 24bits depth
So: 720x576x24 / 8 = 1.244.160 bytes = 1215 Kb
Here is the BMP of VUplus Original SplashScreen:
  • Splash.zip
Belgomorisien
bonsoir, vous sauriez m'aider, quand j'enregistre une chaine (tf1) et j'arrive pas a regarder une autre chaine (canal +) sur mon vu+duo 2 avec image openpli ?merci d'avance
Belgomorisien
Good evening, can you to help me, when I record a channem (TF1) and I get to watch not another channel TV (Canal +) i have a vu + 2 Duo with OpenPLi image? thank you in advance
Belgomorisien
Good evening, can you to help me, when I record a channel (TF1) and I can't get another channel TV (Canal +) I have a vu+ 2 Duo with OpenPLi image? thank you in advance
Moderator
Here ... no support for other images than Open Black Hole or Blackhole Vu+ Images, sorry!
And, by the way, TF1 and Canal +, are both encrypted channels, so i would ask and invite you for reading the forum rules --> http://www.vuplus-community.net/rules.html
lucaxx88
don't work for me...
I follow your step by step...
lucaxx88
Download
Splash_cfe_auto.bin
Put in
X:/vuplus/duo2
Delete other file
Turn off
Insert pen drive for flash
But not work.
This tutorial work for all Vu + and all image?
lucaxx88
What steps?
Where did you put the files?
Do it the wrong way ... and brake your STB :wallbash:
Download
Splash_cfe_auto.bin
Put in
X:/vuplus/duo2
Delete other file
Turn off
But not work.
Moderator
Download
Splash_cfe_auto.bin
Put in
X:/vuplus/duo2
Delete other file
Turn off
But not work.
The process is the same for flashing ... you have to remove all your usb devices ...
You are trying it on a Duo2, right?
