Hi I just had to put a new image on my vu duo+ so lost my lcd display it used to look similar to yours how do I install yours on my boxI thought as setting up the LCD display on the Duo2 is much easier than it was for the Ultimo, that members could post up there layouts for others to use.
The best ones will be added to the BH addon server (if you would rather they are not added to the server, then just make it clear in your post and we won't add it).
Please post a screenshot to show how it looks.
The file you need to upload can be found in /etc/enigma2
Here is mine to kick things off with:
To get the background to work, just add the included folder to /media/usb
thanks
