you could try the port in the line from 8001 to 8002 only works if you have transcoding setup on solo2 and duo2 try in transcoder settings 8002,1,auto,480p
example:
<stream_url><![CDATA[h**p://192.168.2.2:8001/1:0:1:65:65:53:CE40000:0:0:0:]]></stream_url>
change to
<stream_url><![CDATA[h**p://192.168.2.2:8002/1:0:1:65:65:53:CE40000:0:0:0:]]></stream_url>
for ppl that are having problems change the meo.xml remove the <channel> at the start and the end of xml that is not closed and i dont think its meant to be there anyway had same prob removed all good sd an hd no transcoding bh 2.1.0 duo2 sammy f5400 u dont need mediatomb for this but tuner server is good for creating m3u files thats you need to get http feed from.
example:
change to.
<?xml version="1.0" encoding="UTF-8" ?>
<items>
<channel>
<title>RAI 1</title>
<description></description>
<stream_url><![CDATA[h**p://192.168.1.30:8001/1:0:1:65:65:53:CE40000:0:0:0:]]></stream_url>
</channel>
<channel>
<title>HOT</title>
<stream_url><![CDATA[h**p*//192.168.2.2:8001/1:0:1:139A:30:36:CE40000:0:0:0:]]></stream_url>
</channel>
</items>
RESPECT TO DanielFran iv been looking for this fix for ages when i first saw this thread I thought it was too hard but it was a doddle.
it was basically this: for my f5400
1. download DanielFran uploaded widget nStream
2. download samywidgets app v1.1 current from h**p*//download.samygo.tv/PC%20Applications/
3. replace in notepad meo.xml with your channel http feed from any of your channel m3u files change just a few first to try
4. save zip the file up again open samy widgets tick the box note ur address at the bottom
5. go to tv and follow steps (please note following are only for f series please check samygo wiki for your model, i only had to enter develop as user on mine with no password)
Procedure:
Press the smart hub key
Login to the develop account (Menu--->smart features--->Samsung Account--->Login (credentials are user name: develop; password: sso1029dev!)).
On the smart hub screen there is a 'MORE APPS' tab at the BOTTOM, click that.
Select OPTIONS, on the TOP RIGHT corner of screen that comes up.
Select IP SETTINGS from the drop down that comes
Enter the IP of your pc
Select OPTIONS on the TOP RIGHT corner
Select APP SYNC from the drop down list.
6 switch tv off and on go into app 1,neo,"rt1(or your renamed channel) and heypresto
thanks 1ns again to DanielFran for taking the time out to write all that.
next mission if any 1 knows how to stream through dlna to panny vt30 and vt50 that great
tip for the day: ****** all the way Cs
ps, please dont remove this post moders i normally never post to help people but this fix is in high demand and not enough is being done to save the planet so heres my 2 pennys
