How to take a screenshot ?
Justin Jungoo Lee
Hey guys,
I've recently bought Vu+ Duo, and put BH image on it.
Sometimes I feel like to take a screenshot of whole screen not recording a video.
Is there any way to do that? I've been searching for a while in this forum but couldn't.
Cheers,
angelofsky1980
BlackHole Driver Specialist
Hey guys,
Cheers,
You can use the "grab" utility.
Log in into your box via telnet or ssh connection and execute the following command:
grab -dp /tmp/filename.png
The screenshot will be located into /tmp box folder named filename.png
Justin Jungoo Lee
thank you, angelofsky1980!!
connected to STB over telnet (id:root), then used telent command, grab,
then transfered the .png file into my PC through FTP.
It's perfect :) !
