fabiogesto
hey anyone help?
I have found some details how maybe we can play m3u files in Samsung TV directly.
I did not try because I did not have yet a TV with DLNA, but maybe someone can try make some changes in config file and post here the result.
The idea is to map file extension to a new value that TV like
This config file is used by a Buba, but probably we can reuse some elements for our VU+:
Code:<?xml version="1.0" encoding="UTF-8"?> <config version="1" xmlns="http://mediatomb.cc/config/1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://mediatomb.cc/config/1 http://mediatomb.cc/config/1.xsd"> <server> <interface>eth1</interface> <ui enabled="yes"> <accounts enabled="no" session-timeout="30"> <account user="mediatomb" password="mediatomb"/> </accounts> </ui> <name>bubba</name> <manufacturerURL>http://www.excito.com/</manufacturerURL> <modelname>BUBBA|TWO</modelname> <modelnumber>1.0.0</modelnumber> <udn>uuid:7460cfad-c089-468b-866e-6936039a3e2d</udn> <home>/var/lib/mediatomb</home> <webroot>/usr/share/mediatomb/web</webroot> <storage> <mysql enabled="yes"> <host>localhost</host> <username>mediatomb</username> <database>mediatomb</database> <password>RSA5EhrKLXUV</password> </mysql> </storage> <protocolInfo extend="yes"/><!-- For PS3 support change to "yes" --> <custom-http-headers> <!-- Samsung needs it --> <add header="transferMode.dlna.org: Streaming"/> <add header="contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000"/> </custom-http-headers> <!-- <extended-runtime-options> <ffmpegthumbnailer enabled="yes"> <thumbnail-size>128</thumbnail-size> <seek-percentage>5</seek-percentage> <filmstrip-overlay>yes</filmstrip-overlay> <workaround-bugs>no</workaround-bugs> </ffmpegthumbnailer> <mark-played-items enabled="no" suppress-cds-updates="yes"> <string mode="prepend">*</string> </mark-played-items> </extended-runtime-options> --> </server> <import hidden-files="no"> <scripting script-charset="UTF-8"> <common-script>/usr/share/mediatomb/js/common.js</common-script> <playlist-script>/usr/share/mediatomb/js/playlists.js</playlist-script> <virtual-layout type="builtin"> <import-script>/usr/share/mediatomb/js/import.js</import-script> </virtual-layout> </scripting> <mappings> <extension-mimetype ignore-unknown="no"> <map from="mp3" to="audio/mpeg"/> <map from="ogg" to="application/ogg"/> <map from="asf" to="video/x-ms-asf"/> <map from="asx" to="video/x-ms-asf"/> <map from="wma" to="audio/x-ms-wma"/> <map from="wax" to="audio/x-ms-wax"/> <map from="wmv" to="video/x-ms-wmv"/> <map from="wvx" to="video/x-ms-wvx"/> <map from="wm" to="video/x-ms-wm"/> <map from="wmx" to="video/x-ms-wmx"/> <map from="m3u" to="audio/x-mpegurl"/> <map from="pls" to="audio/x-scpls"/> <map from="flv" to="video/x-flv"/> <map from="avi" to="video/x-avi"/> <map from="vob" to="video/x-vob"/> <map from="mkv" to="video/x-mkv"/> </extension-mimetype> <mimetype-upnpclass> <map from="audio/*" to="object.item.audioItem.musicTrack"/> <map from="video/*" to="object.item.videoItem"/> <map from="image/*" to="object.item.imageItem"/> </mimetype-upnpclass> <mimetype-contenttype> <treat mimetype="audio/mpeg" as="mp3"/> <treat mimetype="application/ogg" as="ogg"/> <treat mimetype="audio/x-flac" as="flac"/> <treat mimetype="image/jpeg" as="jpg"/> <treat mimetype="audio/x-mpegurl" as="playlist"/> <treat mimetype="audio/x-scpls" as="playlist"/> <treat mimetype="audio/x-wav" as="pcm"/> <treat mimetype="audio/L16" as="pcm"/> <treat mimetype="video/x-msvideo" as="avi"/> <treat mimetype="video/x-divx" as="avi"/> <treat mimetype="video/mp4" as="mp4"/> <treat mimetype="video/x-vob" as="avi"/> <treat mimetype="video/x-matroska" as="mkv"/> </mimetype-contenttype> </mappings> </import> <transcoding enabled="no"/> </config>
Sorry but this config not detect Mediatomb in Samsung TV.
Please.....Is it possible with a Samsung TV streaming directly Vu+?
Regards from Spain
<config version="2" xmlns="http://mediatomb.cc/config/2" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://mediatomb.cc/config/2 http://mediatomb.cc/config/2.xsd">
Read /usr/share/doc/mediatomb-common/README.gz section 6 for more
information on creating and using config.xml configuration files.
<server>
<ui enabled="yes" show-tooltips="yes">
<!-- Username and Password Mediatomb Account -->
</accounts>
</ui>
<name>MediaTomb</name>
<udn>uuid:c428ce54-f29a-4ebe-83d5-730ae14a0b32</udn>
<storage caching="yes">
<sqlite3 enabled="yes">
<database-file>mediatomb.db</database-file>
</sqlite3>
<mysql enabled="no">
<!-- Username and Database name for Mysql -->
</mysql>
</storage>
Uncomment the lines below to get rid of jerky avi playback on the
DSM320 or to enable subtitles support on the DSM units
<add header="X-User-Agent: redsonic"/>
<!-- Comment the 2 lines below if you have a Freebox -->
<add header="contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=017000 00000000000000000000000000"/>
<manufacturerURL>redsonic.com</manufacturerURL>
<modelNumber>105</modelNumber>
<!-- Uncomment the line below if you have a Telegent TG100
<upnp-string-limit>101</upnp-string-limit>
<ffmpegthumbnailer enabled="no">
</server>
<dvd-script>/usr/share/mediatomb/js/import-dvd.js</dvd-script>
</virtual-layout>
</scripting>
<mappings>
<map from="mka" to="video/mpeg"/>
<!-- MKV support -->
<map from="mkv" to="video/mpeg"/>
<!-- Uncomment the line below for Freebox mkv support
<map from="mkv" to="video/x-matroska"/>
<!-- AVI/DIVX support -->
<map from="avi" to="video/mpeg"/>
<!-- Uncomment the line below for PS3 divx support
<map from="avi" to="video/divx"/>
<!-- Uncomment the line below for D-Link DSM / ZyXEL DMA-1000 avi support
<map from="avi" to="video/avi"/>
<map from="application/ogg" to="object.item.audioItem.musicTrack"/>
<treat mimetype="audio/mp4" as="mp4"/>
<treat mimetype="application/x-iso9660" as="dvd"/>
<treat mimetype="application/x-iso9660-image" as="dvd"/>
<treat mimetype="audio/x-matroska" as="mka"/>
</mappings>
<online-content>
<!-- Make sure to setup a transcoding profile for flv -->
<YouTube enabled="no" refresh="28800" update-at-start="yes" purge-after="604800" racy-content="exclude" format="flv" hd="no">
<favorites user="FAVORITES USER HERE"/>
<standardfeed feed="most_viewed" time-range="today"/>
<playlists user="FAVORITES USER HERE"/>
<uploads user="FAVORITES USER HERE"/>
<standardfeed feed="recently_featured" time-range="today"/>
</YouTube>
<Weborama enabled="no" refresh="28800" update-at-start="no">
<playlist name="Active" type="playlist" mood="active"/>
<playlist name="Metal" type="playlist">
<filter>
<genres>metal</genres>
</filter>
</playlist>
</Weborama>
<AppleTrailers enabled="no" refresh="43200" update-at-start="yes" resolution="640"/>
</online-content>
</import>
<transcoding enabled="no">
<mimetype-profile-mappings>
<transcode mimetype="video/x-flv" using="vlcmpeg"/>
<transcode mimetype="application/ogg" using="vlcmpeg"/>
<transcode mimetype="application/ogg" using="oggflac2raw"/>
<transcode mimetype="audio/x-flac" using="oggflac2raw"/>
</mimetype-profile-mappings>
<profiles>
<profile name="oggflac2raw" enabled="no" type="external">
<mimetype>audio/L16</mimetype>
<accept-url>no</accept-url>
<first-resource>yes</first-resource>
<accept-ogg-theora>no</accept-ogg-theora>
<agent command="ogg123" arguments="-d raw -o byteorder:big -f %out %in"/>
<buffer size="1048576" chunk-size="131072" fill-size="262144"/>
</profile>
<profile name="vlcmpeg" enabled="no" type="external">
<mimetype>video/mpeg</mimetype>
<accept-url>yes</accept-url>
<accept-ogg-theora>yes</accept-ogg-theora>
<agent command="vlc" arguments="-I dummy %in --sout #transcode{venc=ffmpeg,vcodec=mp2v,vb=4096,fps=25,aenc=ffmpeg,acodec=mpga,ab=192,samplerate=44100,channels=2}:standard{access=file,mux=ps,dst=%out} vlc:quit"/>
<buffer size="14400000" chunk-size="512000" fill-size="120000"/>
</profile>
</profiles>
</transcoding>
</config>
Hi,
i wonder if it would it be possible to integrate that patch for mediatomb
in future release of BH. thank you
Hi,
i Wonder if it would it be possible to integrate that p
Please denon54 stop cross posting.
Many thanks.
Even using that patch it is not possible to stream m3u files throw your Samsung Smart TV!Hi,
Is this Patch already included in the new Blackhole Release?
Note: For new Samsung TV since 2012 it might needs to apply a patch to mediatomb! Read it carrefully here: sourceforge.net/p/mediatomb/patches/37/
but this alternative isn't running for me as well. maybe you can have a look. Thanks
