Very nice! I like transparent backgrounds in combination with deep blue. A little transparency in main OSD may help the overall theme. Thanks MX![]()
I think, the bold font should be replaced with a plane one in the main menu and EPG.
Nope! I take it back. MX was right and now I can say that the transparency may not be a good idea in this skin, at least on these shots view on PC.It's not a bad idea
However I am concerned about the size of the skin
and performance in solo and duo.
It is very usable on the new boxes
but I'm more of an idea to add inside image
addition for a user changes in the skin
example some fonts.
Only one problem, I will have to constantly switch between RedBlack, Adriatic Blue, Red Diamond, ...! Do you think my box will survive this?!
MX, I think you are going to make us just view your awesome skins, instead of viewing TV shows!![]()
When can we get this cool skin matrix?
