Skin boot in build
Polar Bear
What files to edit in build to get skinn to boot on fyrst boot on all vu box
I see in engima pack settings files for difrent dreambox do they work ?
Hi PB,
I have only this information.I hope that's what you ask.
You can find the recipe in:
openvuplus/meta-bsp/common/recipes/vuplus/vuplus-bootlogo
But you gotta know much more to build a customized image.
For more information and help, unfortunately we do not have time.
Rgd MX
Thenks for the replay my friend but I am not asking abut bootlogo
But how to adust skin in the build so it boot in the skin
PS. I did build 2,1 Vu+ Polar team Thor beta some time ago but that was for fun as Dreambox image was ready for public
skin.py is coding and if users wont to use difrent skin later on that dont work so good
Also I cult rename my skin and edit skin.xml to default-HD skin but that is dont not the way I like to do it.
In Dreambox ( I hat for got the VU+ ipk name ) enigma2_3.999git20130607-r9.0_mips32el.ipk in usr/share/enigma2/defaults/Dream/ we hat settings files for all box
It can be edit , orginal its : config.skin.primary_skin=Default-HD/skin.xml then rebuld and bitbake.
Also if som one know the name off the VU+ enigma2 pack it wult be nice as I did lost in when my HDD did cras and it dont hat same name as DMM pack do
I wonder way ,but thats difrent story when we talk abut respegt .
I dont got VU box my slef so I am build in it blind
@paolino I am told Polar build VU+ image work wery good and stabill and never crass but I dont know my self. as its dust a faver to a good old friend.
You should study a little the Vu+ sources.
skin.py is not fixed it defines only the default setting exactly what you have asked. Then the user can choose a different skin.
Like already replyed to you in the above post the setting fo the default skin is defined for Vu+ in skin.py.
But Vu+ code in OE2 applyed a patch at compilation time to change this setting.
So you have to patch the patch.
The patch is here:
http://code.vuplus.com/gitweb/?p=vu...dc66bfc244ace9ffe32fad19;hb=refs/heads/master
The line of the patch that you have to change is this:
-config.skin.primary_skin = ConfigText(default = "skin.xml")
+config.skin.primary_skin = ConfigText(default = "Vu_HD/skin.xml")
rgds
Thenks Shiro :)
I will look in to this LOL only sad thing I can not test my self :) but It is a challenge to do this blindly
LOL yes I know But I hat forget that name and lost my edit to it ;) when my hdd did crass but shor I can find it agen but wult dust be more easy know then name off it or the fyrst letters but look thru all mips32el.ipk folder to look for it
I know what is in it ;) I hat go thru it befor
It's used in this form to distinguish, what is done for. For example xxxxxx_all.ipk is for all enigma2 devices. If you use xxxxxxxx_solo2.ipk, means that is done only for Solo2 and so on...
PS: I'm sorry for your HDD :(.
Yes paolino I know that and I do it for all box I did build ;) I hat all vuplus 2.1 cvs build in my hdd agen now also all DMM OE2.0
But rison I use VUPlus not diftent github is becurs I like to work from fress cvs image its is a respegt to difrent team .
find this ipk did take my last time I maby hat to fress my memory
