SatDreamer
Hello everyone,
Using the Duo for years to stream directly to the PC. This has recently stopped working. Network/firewall are ok and I made no changes to hardware/software/options. Using the older Black Hole 2.1.7.
When I click the Stream button on Webif and send it to the PC media player, nothing happens. So, I downloaded the stream.m3u file to examine it.
Note that I had stored in the past several of these .m3u files on my PC (each for different channels), and these older files still work perfectly (the Duo streams normally). I don't what caused this change.
Newer (not working) .m3u file:
#EXTM3U
#EXTVLCOPT--http-reconnect=true
#EXTINF:-1,LA7
http://192.168.1.5:8001/
Older (working) .m3u file:
#EXTM3U
#EXTINF:-1,LA7
#EXTVLCOPT: program=71 (added a space before 'program' because it's turned to a smiley)
http://192.168.1.5:8001/1:0:1:47:1770:110:820000:0:0:0:
Clearly some information is now missing, but I don't know which option controls this. Any ideas?
#EXTM3U
#EXTINF:-1,LA7
#EXTM3U
#EXTINF:-1,LA7
rogram=102
Glad you solved.
