Vu+ Solo4K tested for you!
The LCD display on the front is 3.5” and gives an 18bit, 262000 colour picture, you can use this to view the time, station name / number, current program information etc, however you can also use is as a 2nd screen, and watch tv on the LCD in real time.
Hi, How to use LCD screen inreal time? or other screen options? May someone knows about this "The front 3.5” LCD shows vivid streaming videos while you are watching TV as Mini TV. It also keeps the additional interesting information features with using various plug-ins as you enjoyed with Duo2" (it's from manual)
Press and hold the blue button, then select Enable MiniTV
does anybody know, if the transcoding feature is hardware or sofware. software transcoding is poor. but if this is hardware based, that would be great as duo2 is hardware based, and picture quality is better.
Very sorry, but that was a mistake listed in the features (I have now corrected the feature list).
At the moment there is no transcoding on the Solo4K, it might be possible that Vu+ will add it at a later date, but I do not know for sure.
It seems that Vu+ are now working on 1080p Transcoding for the Solo4K
Apologies if my question is inappropriate. Where to get Blackhole for solo 4k and the TS panel. Does this machine only support os cam and not the others like ***** and mgcam!!
What an excellent 1st post.
You have won a 7day ban, may I suggest you take this time, re-read the rules that you agreed to when you signed up on this board less than 24 hours ago.
Great thanks for this excellent tutorial.
Could someone give me a link for the easiest way to install ***** on Black Hole ..
Rgds
Rgds
Read our board rules, it's forbidden to talk about illegal stuff.
You are banned for a week!
  • Like
Reactions: Ev0
hello ,
what the best Movie player on the solo 4K blackhole,ik heb 3 movies MKV 2 of them UHD and one is HD,when i play them it's black screen with only voice ...?
please help
Anyone tried to stream 4k to a PC? I usually use my PC as a second TV when my WAT uses main TV set...
I used Solo2 and Media Player Classic - BE to watch UHD on my PC. I have Sandy Bridge overclocked to 4500 MHz, NV GeForce 970 with HDMI 2.0, and Dell monitor capable 4096x2160 resolution. Processor usage was from 85 to 98%. I have no UHD TV to test full UHD resolution.
Nice! But is it 4K@60fps? And one more question. To watch 4K channels I need CI+ for CAM modules. Is there + ?
I don't know if is 4K@60fps
A 4k channel is equal to another channel (SD or HD) so if it's crypted a CI CAM module is needed. I don't know if the CI slot is enabled to "+" extension.
