Vu+ ULTIMO Firmware Upgrade
Mito
Update FPGA v 4.5
Fix High/low symbolrate channel scan problem.
There are two ways to upgrade your box.
One is using your USB memory stick and the other is upgrading directly from the internet.
Option A) Using USB memory stick.
1. Download the file named TS_PRO.dat_FPGA_4.5.zip attached to this post and unzip it.
2. Copy the file TS_PRO.dat into USB memory stick.
3. Attach USB memory stick to your box and restart. (or restart GUI)
4. Goto FPGA plugin menu.
5. Select the data file in USB memory stick and start 'Upgrade'.
6. Restart your box.
Option B) Upgrade directly from the internet
1. Goto FPG plugin menu.
2. Download the data file by pressing 'Blue' button.
3. Select the downloaded data file and start 'Upgrade'.
4. Restart your box.
  • TS_PRO.dat_FPGA_4.5.zip
rocuelo
i try to do
AND is a notice saying can't dwonload the checksum file....
any idea why is happening??
ilmago
BH Lover
i try to do
use the instructions posted by Mito...
download the file from this thread and put in a usb pen, then update it choosing TS_pro.dat .
denon54
hello,
i tried to do the upgrade on my ultimo using methode directly from internet,
i follow the procedure and select the TS_pro.dat inside my /tmp.
i confirmed and at the end got a message upgrtade successfull, the box restatr
automatically at the end of the procedure, when it restart and that i go back to
FPGA upgrade , when i tried to install again , i got the same file coming back,
so my question is the upgrade went ok or do i have to do it again, because normally
i shouldn't get the possibility to redownload again the same file if everything gone right?
do you have a ny info about that,
i also have to say that i use Black pole 0.1.3
thank you
ilmago
BH Lover
hello,
thank you
at the moment is not possible to verify the version of the fpga installed as angelofsky1980 said in an other thread, but if you received a successfull message it means upgrade done.
Don Andres
BH Lover
Have both files on a USB stick and have already updated my Ultimo with TS_Pro.dat file .
*mtd5 is only 1 kb , so when I try to update this one as well , I got message " Can't found MD5 file " !
Is it important på upgrade the * MD5 file and if so , where can I find a version bigger then 1 kb ?
I guess without this upgrade HBBTV plugin is useless.
After upgrading the TS_pro.dat file , HBBTV interface is still not working here ?
siksika
the * MD5 is a file cecksum, if you open it there will be a sequence of unknown numbers. in linux if you do "md5sum TS_PRO.dat" the result comes out to be equal to the * MD5 if it is different then the file is corrupt TS_PRO.dat.
then the * MD5 should not be installed! so it is in linux I am new to this world, no matter if I'm wrong rorregetemi.
sorry I translated with google
Smurfik
Update FPGA v 4.5
