Matrix10
Now I understand.
Then there's something wrong with that splitter
If you have a picture without splitter.
This means he does not transmit something as it should because he has to transmit the input signal
1 : 1 at the output.
Have you tried other sources on that splitter that have 50 or 60 Hz ???
If you have the same result with other sources.
It seems he reduces/split the output frequency to two of 30 Hz
