4K,UHD+H.264
kuno55
OK, some observations.
Solo4K enigma2 can't play the UHD video, what is compressed with H264. At the same time, 1080 resolution files it plays, when it is compressed with H264. If the first convert to H265, then it handles that. Can you fix it? I can send sample(s) *.mp4. All UHD TV-s (Samsung, Sony) can do it nicely, maybe you can fold this little failure for Solo4K enigma2?
As from SAT-TV the broadcasts come only with H265, then apparantly based on this? And some codec for H264 is missing or other such thing?
Need2learn
Hello I can play back the 4k channels just fine, which hard drive are you using? I have a SSD and it works great with 4k play back.
numind
hope this crash log file would be enought because most of times crash log just is blank...maybe this is somethign related with 4k bouquets? is the only idea because with any previous vu+ models this didnt happen..
  • enigma2_crash_90.txt
