My Panasonic is Plasma 50 inch 1080p. What will be the best image quality set up in my VU+ uno. Should I set the A/V setting to 720p and use autoresolution plugin to force SD channels to 576p
What is your recommendations? how is your system set up?
I have the same TV,,,@ A/V 1080i,,,!!
And no need to use Auto-resolution,,,may be U can play ( adjust color to your liking) with video enhancement settings!
With seted 1080i in AV without autoresolution and VE ,You will have poorer quality on SD channls because tv work downscaling. I tested this in last few years and I told what give the best results !
I was that disappointed with the picture quality on SD, I was seriously considering switching to a another manufacturer of receiver... Luckily for me I stumbled across this VERY useful post.
Hhahaahaaha ! I have Plasma tv 15 days "old" , Panasonic P42G30 , maybe the best plasma in midle class of this year. Problem is not in tv. I am a very experienced with this and this is my opinion after really much testing.
The only annoying thing with Autoresolution is that the skin resolution fall down when switching to SD channel, which makes the skin and he fontd look ugly.
I have found another solution, i installed VU+ Uno Driver from 17.08.2011 and picture is now very good, without autoresolution, the problem with quality is the driver, newer version picture looks bad
