A Word About 3TB HDDs
i am tired.
you dont' folow instructions.
you cannot partitioned a device if it is mounted and if you don't know what label have.
i have told you many times to post output of commands.
now i will leave, remember to umount devices befre to partiotion them
umount /dev/sda1
umount /media/hdd
and so on depending form the putput of commands.
How should I type the command, I'm trying everything, although it's just returning a whole list off commands instead of the HDD space :/
there is nothing difficoult in type commands and report here but you prefer to make trying by yourself.
You can corrupt the devices in this way.
For the last time:
about hard disk:
boot your box without usb stick
telnet to your box and digit commands:
umount /media/hdd
umount /dev/sda1
use parted following the tutorial and using /dev/sda instead of /dev/sdb
After the disk is partitioned and formatted reboot the box, goto device manager and map the hdd (after reboot)
at the end enter in telnet and digit command
df -h
and let us know if it is ok.
About usb:
boot you box WITHOUT usb stick
goto blue -> blue -> Usb Format Wizard.
follow instructions and plug the usb only when requested by the application.
Sorry Shiro, but I usually only use Windows GUI, although I'm getting to know my way around Parted now. I did accidently deleted the partition on the USB, although I reformatted it to EXT2 using the wizard as it's now recognized by BH.
I unmounted both the USB and HDD using the device manager in the extra settings. As far as I can tell the HDD is /dev/sda and the USB /dev/sdb
When I've used the 'print all' command and the HDD is listed as follows:
Model: ATA WDC WD30EZRX-00M <scsi>
Disk /dev/sda: 3001GB
Sector size <logical/physical>: 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
*** END ***
Now, because I can also see the USB which has disk flags, I'm guessing that I've now got to create disk flags for the HDD, and the fact it hasn't got any is the reason BH cannot see the HDD.
Ok infiltrator now you have to partiotioned and formatted.
Telnet to you box and digit these commands:
umount /dev/sda
parted /dev/sda
mklabel gpt
unit TB
mkpart primary 0 0
quit
mkfs.ext4 /dev/sda1
When mkfs will be complete you can reboot and after the rebbot you will find disk in device manager ready to be mapped.
00
umount /dev/sda
parted /dev/sda
mklabel gpt
unit TB
mkpart primary 0 0
quit
mkfs.ext4 /dev/sda
Just went through it all and I'm getting the following message when using the mkfs command :
dev/sda is entire device, not just one partition!
Proceed anyway? (y,n)
No sorry, it is my error
the correct command is:
mkfs.ext4 /dev/sda1
Just executed the command and I've received the following message:
"File system to small for a journal
Writing superblocks and Filesystem accounting information: done"
Ok it seems that the partition is not created right dimension
umount /dev/sda1
parted /dev/sda
rm 1
mkpart primary 0 -1
quit
mkfs.ext4 /dev/sda1
umount /dev/sda1
parted /dev/sda
rm 1
mkpart primary 0 -1
quit
mkfs.ext4 /dev/sda1
Every time I try to create a partition with the mkpart command I'm always getting the following message:
"Warning: The resulting partition is not properly aligned for the best performance .
Ignore/cancel?"
Ignore/cancel?"
ok use this comand:
mkpart primary ext4 1 -1
I think you can test later the best alignment. For now it is better to see if it works.
so:
quit
mkfs.ext4 /dev/sda1
or you can try this tip:
Cool, I'll have to try it. The good news is the HDD is recognized in BH as 3000.592GB Although because I've got no data on the HDD it doesn't give my the available in the 'BH Recorded Files' menu. I also get the following error message when trying to initialise the HDD within BH:
BH Message
Unable to initialise hard drive
Error: Creating partition failed
*** UPDATE ***
The HDD managed to Initialise, but still it's only showing up as 801112 MB free disc space :/
BH Message
*** UPDATE ***
Again you have made the wrong thing and have not followed instructions.
If you use image inizialization you corrupt partition table.
I was clear to inizalize hdd you have to use command:
mkfs.ext4 /dev/sda1
Now that you have use inizialization you have to delete partition and remake all again
After you have formatterd the hdd with the command mkfs.ext4 /dev/sda1
you have to:
1 Reboot
2 goto device panel and map the hdd to /media/hdd
3 telnet to the box and use command:
mkdir /media/hdd/movie
All done.
you have to:
1 Reboot
All done.
Many thanks Shiro, everything's all working fine now and BH recognizes the full 3TB are available space. It's been an experience and steep learning curve.
Again, thank you for your help and support as I'm sure I wouldn't been able to do this without your help.
Cheers Ian ;)
