About blackhole and openblackhole
younes-o2
Does the openblackhole birth mean the end of Blackhole ? No image blackhole in the future ?? It stops at 2.1.6.1 ('21/5/2015)?
Eragon
Vu+ User+++
See:
http://www.vuplus-community.net/board/threads/open-black-hole-0-1-update-19-06-2015-vu-solose.23481/
Do I have to upgrade to this new Open Black Hole image ?
No you don't have to upgrade to the new Open Black Hole image, this image is completely separate from the original Black Hole image, this is simply a new image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new Open Black Hole image then you can do so.
What about the Black Hole and Black Hole Prism Images ?
For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new Open Black Hole image is an additional project and we are fully committed to all images.
