AF9015 (Avermedia A850 &C)
superplakis
I should have fixed the issue of this pen... in the next days we should relase a driver compatible with Black Hole!!
very great news .....
now I do with a Black Volar and another MiniStick .... well as prove to have both installed ....
may also be installed on the vu + solo? is that I arrive on Monday Vu + Solo.
THANKS TEAM!
papi1962
THANKS TEAM!
You mean that black volar is working? Which driver do you use?
Best regards
superplakis
As dpeddi wrote, we are testing the driver.
At the moment is not public but after tests to verify it's works correctly, will be published.
Stay tuned!
but you can not ask .... especially thanks for the insistence. I personally had already given up on being able to use my Black Volar ... but many other colleagues, I appreciate it, because if you do run will have no need to buy another.
papi1962
Stay tuned!
I have one pen - the seller told me, that is compatible with Avermedia Volar Black HD - but he don't know which driver to use. If I instal it on windows xp is showing like hardwer AF9015
Best regards
