Request Aiutino per prima "flashata" BH su VU+ UNO
Ho flashato la BH usando una terza penna USB.
Ora sembra avviarsi ma non invia segnale A/V e resta in loop qui:
('1[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
080i', ['50Hz', [AUD]: AUDIO_SET_MIXER -836575760
'multi', '60Hz'][AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
('576p', ['50[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
Hz'])
('480p', [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
['60Hz'])
('576i', ['50Hz'])
('480i', ['60Hz'])
setMode - port: DVI mode: 720p rate: 50Hz
-> setting aspect, policy, policy2, wss 16:9 panscan letterbox auto
self.selection: DVI
input selection moved: DVI
inputSelect: DVI
getModeList for port DVI
modeList: [('720p', ['50Hz', 'multi', '60Hz']), ('1080i', ['50Hz', 'multi', '60Hz']), ('576p', ['50Hz']), ('480p', ['60Hz']), ('576i', ['50Hz']), ('480i', ['60Hz'])]
modes for port DVI and mode 720p
('576p', ['50Hz'])
('480p', ['60Hz'])
('576i', ['50Hz'])
('480i', ['60Hz'])
showing config
setValue 100
Setvolume: 100 100 (raw)
Setvolume: 0 0 (-1db)
child has terminated
pipes closed
pipes closed
[ePopen] command: route -n | grep eth0
poll: unhandled POLLERR/HUP/NVAL for fd 28(16)
poll: unhandled POLLERR/HUP/NVAL for fd 30(17)
pipes closed
[Network.py] resolv.conf - opening failed
nameservers: []
read configured interface: {'lo': {'dhcp': False}, 'eth0': {'dhcp': True}}
self.ifaces after loading: {'eth0': {'preup': False, 'predown': False, 'ip': [0, 0, 0, 0], 'up': True, 'mac': '00:1d:ec:02:d6:35', 'dhcp': True, 'netmask': [0, 0, 0, 0], 'gateway': [0, 0, 0, 0]}}
[Toplevel.importExternalModules] Could NOT import external module: AutoTimer
[Toplevel.importExternalModules] Exception Caught
No module named AutoTimer.AutoTimerResource
[Toplevel.importExternalModules] Imported external module: Example
[Toplevel.importExternalModules] Could NOT import external module: EPGRefresh
No module named EPGRefresh.EPGRefreshResource
[WebInterface] checking for SSL Certificates
[Webinterface] started on 0.0.0.0:80 auth=False ssl=False
[WebInterface.registerBonjourService] No module named Bonjour.Bonjour
[Webinterface] started on 0.0.0.0:443 auth=True ssl=True
timeoutCounter: 19
timeoutCounter: 18
timeoutCounter: 17
timeoutCounter: 16
timeoutCounter: 15
timeoutCounter: 14
timeoutCounter: 13
timeoutCounter: 12
timeoutCounter: 11
timeoutCounter: 10
timeoutCounter: 9
timeoutCounter: 8
timeoutCounter: 7
timeoutCounter: 6
timeoutCounter: 5
timeoutCounter: 4
timeoutCounter: 3
timeoutCounter: 2
timeoutCounter: 1
timeoutCounter: 0
selection next item
self.selection: Scart
input selection moved: Scart
inputSelect: Scart
getModeList for port Scart
modeList: [('PAL', ['50Hz']), ('NTSC', ['60Hz']), ('Multi', ['multi'])]
modes for port Scart and mode PAL
('PAL', ['50Hz'])
('NTSC', ['60Hz'])
setMode - port: Scart mode: PAL rate: 50Hz
inputSelect: Scart
('PAL', ['50Hz'])
('NTSC', ['60Hz'])
inputSelect: Scart
('PAL', ['50Hz'])
('NTSC', ['60Hz'])
current: ('Scart', 'Scart')
inputSelect: Scart
('PAL', ['50Hz'])
('NTSC', ['60Hz'])
down
timeoutCounter: 19
timeoutCounter: 18
timeoutCounter: 17
timeoutCounter: 16
timeoutCounter: 15
timeoutCounter: 14
timeoutCounter: 13
timeoutCounter: 12
timeoutCounter: 11
timeoutCounter: 10
timeoutCounter: 9
timeoutCounter: 8
timeoutCounter: 7
timeoutCounter: 6
timeoutCounter: 5
timeoutCounter: 4
timeoutCounter: 3
timeoutCounter: 2
timeoutCounter: 1
timeoutCounter: 0
selection next item
self.selection: YPbPr
input selection moved: YPbPr
inputSelect: YPbPr
getModeList for port YPbPr
modes for port YPbPr and mode 720p
('576p', ['50Hz'])
('480p', ['60Hz'])
('576i', ['50Hz'])
('480i', ['60Hz'])
setMode - port: YPbPr mode: 720p rate: 50Hz
inputSelect: YPbPr
('576p', ['50Hz'])
('480p', ['60Hz'])
('576i', ['50Hz'])
('480i', ['60Hz'])
inputSelect: YPbPr
('576p', ['50Hz'])
('480p', ['60Hz'])
('576i', ['50Hz'])
('480i', ['60Hz'])
current: ('YPbPr', 'YPbPr')
inputSelect: YPbPr
('576p', ['50Hz'])
('480p', ['60Hz'])
('576i', ['50Hz'])
('480i', ['60Hz'])
down
If you don't have the message in the display .. something like: "update complete remove usb and reboot" it means that the flash via usb is not complete.
E' in loop continuo qui. Appena finito il Timeout ricomincia:
inputSelect: YPbPr
('576p', ['50Hz'])
('480p', ['60Hz'])
('576i', ['50Hz'])
('480i', ['60Hz'])
down
timeoutCounter: 19
timeoutCounter: 18
timeoutCounter: 17
timeoutCounter: 16
timeoutCounter: 15
timeoutCounter: 14
timeoutCounter: 13
After the flash I have received the message.
I try another one flash via USB.
Thanks a lot for your support! :D
Ho attivato il plugin Hdmi-cec e ha switchato sull'hdmi. Su un Samsung 24 pollici di qualche anno fa.
Ora ho collegato il vu al 46 serie 8000 Samsung e non c'è modo di farglielo vedere. Solo scart.
Hai aggiornato il firmware della TV?
Hai provato tutte le porte HDMI a tua disposizione?
Si ho provato tutte le Hdmi. Il firmware del Samsung è aggiornato.
Il puglin Hdmi-cec attivo o meno ha qualche influenza?
Sul 24 ho risolto attivandolo.
Mi dimentico sempre che i cavi HDMI sono digitali e possono fare la differenza :)
Scusate se mi intrometto anche io ho un V+1 che passando dalla BH171 alla BH 172 flasato normalmente ma quando spento dietro e riacceso carica la BH 172 esce il telecomando sullo shermo per la programmazione ma ciò è impossibile in quanto il telecomando manuale non risponde più ai comandi.
Ho installato diverse immagini ma con tutte la stessa cosa, le batterie sono state cambiate ma nulla.
Tenete conto che sono principiante. Grazie:(
Togli qualsiasi periferica diversa dal cavo SAT e dal cavo HDMI ... verifica anche che non ci siano fonti IR (infrarosse) che inibiscono il funzionamento del telecomando del box.
Angelofsky ciao: tutte le periferiche le ho tolte daltronde non ho ne hdd ne altro l'unica cosa è il cavo antenna e hdmi.
Per la verifica delle fonti IR non ho idea di come farla.
Grazie:(
