Many thanks Pyromon, but I'm not as expert as you are ;-)
So I'll wait for an upcoming version compatible with OBH.
If you know about the Albatros' author, could you please ask him such version.
Pyromon thanks a lot for the update... I still have an issue "not satisfied dependencies" when installing "livestreamer" and "livestreamersrv", please refer to the attached screnshot.
Could you help? (still using Vu+SoloSE running the latest OpenBH 0.1 - 20150619)
thanks for the great work.
very nice plugin beter than arabic-entertainement and tsmedia.
tested on openatv 4.2 it worked fine (teledunet ok Glarab a bit slower and unstable) , but today teledunet not working at all even with update ids and Glarab slower than usual. and yoolive when i presss ok button nothing hapends.
please keep up the good work and hope a new version 1.7 will fix these isssues.
- teledunet fixed ( login and change channel one time )
- streamcomplet fixed
- some changes to ilive
- thai tv added
- kika.de added ( takes some time to load the list in first screen - just wait
- ourmatch champions leaugue links fixed
- streamking fixed
- teleboy will be fixed in next release
- goldvod ( polish streams ) added
- teleboy fixed ( you need to edit c.txt in Albatros folder and insert your own cookie )
- showsport channels added
- removed python-requests
- streamingHD fixed
