Army_ DarkSky-HD_VU_BH2.x.x_v.1.0
This skin is my favorite too. It is not compatible with Blackhole 3.0.3 anymore. Is there any think close to this and compatible with BH3.0.3 ? I have tried a few from download site but quit different from this one. The problems are the receiver must restarts every time when I change the skin. It is hard to try everyone. Is it possible that the skin developer upload some skin samples to this website? I trust it will help everyone in this community.
Afaik, no. Because The size and fonts colour used are the same or nearly, on the lastest MX skins. Although, you can separate "services" from "Epg Info" ... with the icons type of services.
3.0.3.b. de calışmıyuyor skın duzeltırsenız ıyı olur bıde 1280..720. yaparsanız super olur saygılar
hi dear Matrix10
please design this skin in 1080 size and 220 picon size
i like this skin
thanks & hope to have a good year
Thanks Matrix10,
this is one of the best Skins I know.
Very nice work. And with this Skin a very good Image.
Thanks to the TEAM......
Would it be possible to have kraven-Skin with the new api???
Greetings Slaroni
Hi thanks for your work , i'm on 3.0.2 i try update blackhole online , no sucess , i download your skin for v3.0.3 it was downloaded and installed , but no change , do i miss something to do after install ?
ok i find i have to change in menu > skin ... sorry for noob question :)
but i m sad skin dont resize my picon , they are bit too big for you skin
Hi,
At BH 3.0.4.D, after switching to Army DarkSky HD (for BH 3.0.3 and up ver), the SSL connection stops working.
Do you observe this effect at your tuners?
My tuner is VU+ Duo.
