Hello i have been trying to contact Army about this skin and no lucky .
is it possible to get this one to work with newest blackhole without to compromise his copyrights.
i use this skin on mu vudo and wants it in my vuduo2 with newest blackhole
Kind regards
Seth
Hi Seth,
AFAIK, this army skin is an very outdated one. Cause the stability of the image, and i have no shure that it works, use only Matrix10 FullHD skins to avoid issues, that you can download from the ADDONS FEEDS.
Matrix10 skins are fully supported for the latest images, instead of this one. Even if you can have it rolling on your STB with the image installed, i don´t think that anyone should fix it for you.
Note: This is my opinion, and i think is MATRIX10 opinion too.
