Army_BrioSTD_HD
rurs
Very happy with this skin, however movie list is different after update from 1.4.5 to 1.4.6.
Clock is added to bottom of screen, and scrolling down list, last item can't be highlighted, but page jumps to next page...hard to describe, but obvious in use.
Is this a skin issue, or due to underlying changes? Any way to remove clock from movie list?
Thanks
Army
Thanks
Purtroppo la skin la devi tenere così non mi sembra un problema grave è una combinazione di font e di spazi per avere il Movielist che vada bene per le 4 combinazioni
-list style default
-list style compact whith description
-list style compact
-list style single line
Le trovi schiacciando il tasto menù
Ciao
rurs
I use list style default in both 1.4.5 and 1.4.6, yet the navigation is not the same. There is a list of 5 recordings per page. In 1.4.6, the last item can't be selected on the first page, the list jumps to the second page, with the fifth item now becoming the first on the second page....no big deal, I'm just curious as to why the same skin behaves differently.
Am I right that there is no clock in 1.4.5 in movielist, but it's there in 1.4.6?
Thanks
-list style default
-list style compact
Ciao
Army
Thanks
Sostituisci questo file e tutto va a posto
  • skin.zip
pedro976
Hi, I would be interested to install this skin , but I can not find to download via blackhole .
How can I do ?
It's compatible with my Vu+ Zero with BH 2.1.4 ?
Thank You
