audio issues using av reciever
Hi everyone,
Some more informations :
I went from 2.0.8.1 (OK) to 2.0.9.1 (audio problem).
Downgrade to 2.0.9.0 : audio NOK
Downgrade to 2.0.8.1 : audio NOK ! So i reflashed 2.0.8.1 but reinstalled everything (channels scan, plugin...). All other up/downgrade I restored "personnal backup". Atfer that the sound was OK again.
I tried to reupgrade to 2.0.9.0 and the sound still works. But I noticed that I can't power it on with the remote control, which was working until now (remote control code is ON, already had the problem with 2.0.5 but it disappeared)
I will try to move to 2.0.9.1. Do you plan to include the new drivers in a 2.0.9.2 soon ?
Hope it helps...
This happens to me on blackhole 2.0.9.1 especially after switching off box or restarting enigma. Very annoying cos I have to restart the box till it works.
I would like to report possible audio problem of BH 2.0.9.1. I just noticed that many of IPTV HD stream will loss audio when I use BH 2.0.9.1. The picture quality is oky. It may indicate the network speed is oky (Bufferring time is short). I have post this issue for a while,but no reply. I think it may be worth to look at by a coder or VU+ enginner.
Hi everyone,
Hope it helps...
Replace VUDuo2 Drivers with 20140424 Audio Issue is Solve if u have VU Duo2 Receiver
Think i'll just wait for next image update rather than try 2.0.9.1 and then have to fallback to 2.0.9 which I've done each time "NEW" drivers were issued ....
So roll on 2.0.9.2 or 2.0.10 !!!
I've made some tests with Solo first generation box (it's the only avaiable in my current location) and I've detected your same issue. No audio but video is OK.
With VLC and Windows I've detected the specs of audio track of one of the URLs you have sent me via PM:
Type: Audio
Original ID: 482
Codec: MPEG AAC Audio (mp4a)
Channels: Stereo
Bitrate: 48000Hz
AAC Extension: SBR
Reprt these infos to Vu+ Dev team (www.vuplus.com) with the two URLs.
